Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Jul 26, 2023 at 8:44 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Love you babe
    Slashaar and Tacomania[QUOTED] like this.
  2. Jul 26, 2023 at 8:48 AM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Slashaar and CygnusX191[QUOTED] like this.
  3. Jul 26, 2023 at 8:52 AM
    Tacomania
    Tacomania IG: _tacomania
    Crazy Mike
    86 4runner / 2016 SR5 Tundra
  4. Jul 26, 2023 at 9:25 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Tacomania[QUOTED] and Slashaar like this.
  5. Jul 26, 2023 at 10:10 AM
    Missouriprerunner
    Missouriprerunner Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    I've searched but don't see any write ups for installing leafs and rear shocks. Am I just useless with the search tool or is there legit not one?
    Trying to see what I'm getting myself into
    CygnusX191 and LarryDangerfield like this.
  6. Jul 26, 2023 at 10:12 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I don't say this lightly, if I can do it, you can do it. Just watch a YouTube video and follow along with each step, that's what I did.
    CygnusX191 and Shellshock like this.
  7. Jul 26, 2023 at 10:54 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    I did the front UCA and coilovers myself and that wasn't too bad. Only threw like 3 wrenches.
    It doesn't seem complicated as long as shit lines up. I saw a video where a guy used a ratchet strap to pull on the drum to get things to align after his truck shifted on him.
  8. Jul 26, 2023 at 11:27 AM
    Shellshock
    Iowa
    It’s not that bad. Or just buy some pizza and have @CygnusX191 do it
    CygnusX191 likes this.
  9. Jul 26, 2023 at 11:56 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    @CygnusX191 can have all the pizza and beverages he wants, he wouldn't even need to do anything just supervise and protect me from myself :cheers:
    Willy224, CygnusX191 and Shellshock like this.
  10. Jul 26, 2023 at 12:19 PM
    HIYota
    Angel
    Its a pretty straight forward install *knocks on wood*. Most issues I've seen have been rust related when it comes to the shocks. Then it becomes a pain in the ass and having to get creative. You replacing the entire leaf pack or installing an add a leaf?
  11. Jul 26, 2023 at 1:29 PM
    Shellshock
    Iowa
    yep. I had that issue doing the shocks on my taco
    got myself one of these to get that stupid top nut off
    https://www.menards.com/main/hardwa...-e5ad-4a0b-a2ba-df770a857220&ipos=1&exp=false
    CygnusX191 and HIYota[QUOTED] like this.
  12. Jul 26, 2023 at 2:01 PM
    HIYota
    Angel
    Mid-west and suspension parts don't like to play nice. Worse was the one time @G.T. place, the metal sleeve in the bottom bushing rusted to the bolt. Had to cut off the bottom eyelet, get most of the bushing off, apply heat and then separate the sleeve and bolt. @Missouriprerunner my best advice to make things go smooth is check your bolts ahead of time. If they look like shit buy some spares ahead of time. Hopefully having a 2018 means it won't be bad, I just tend of operate under Murphy's law.
  13. Jul 26, 2023 at 3:10 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Got new greasable shackles from bamf, bushings and greasable pins, deaver u402 leaf packs, and dobinson extended travel shocks.
    Truck is a 2018 but spent all it's life up until last year in Texas so it hasn't see salt but one winter so far. It looks great underneath so far from what I've seen.
    CygnusX191 and JTFisherman like this.
  14. Jul 26, 2023 at 4:38 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It ain't bad.
    I mean ......
    :D if you do the heavy lifting. I've got a torn up shoulder and a rough lower back (government will do that to you)
    2nd gen rusty gen. "this one time, at @G.T. 's place ..." Lol
    Hot damn sounds like you've got the goods.
    Lemme do some asking around, if you're free this weekend.....
  15. Jul 26, 2023 at 5:08 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    You guys are awesome.
    I think this has been the only month of my life I've been busy every weekend. I'm still busy this weekend and the weekend after but after that I should be free until Thanksgiving lol
    CygnusX191[QUOTED] likes this.
  16. Jul 26, 2023 at 5:56 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Just give us a shout out here and we'll put something together. I know there's a few of us aching to get together and break somet.... I mean fix some things and mod some things and make some trucks better. :sawzall:
  17. Jul 26, 2023 at 8:05 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Hell yea
  18. Jul 27, 2023 at 5:28 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    As long as nothing is seized (which seems to never be the case) its a fairly easy job with the right tools and an extra set of hands.
    Shocks are top and bottom bolts, leafs are more involved.
    -You'll want tall jack stands to support the rear end of the truck. You'll want enough room to droop your axle out or you'll end up doing one side at a time so a tire can be on the ground.
    -Then you'll support the rear axle with a jack while you unbolt the ubolts.
    -Once that's loose, make sure your ebrake cable isn't still attached to the leafs.
    -undo the rear bolt on your leaf spring (I'd do this part one side at a time so you aren't dropping both), then lower the axle till you can lift the leaf off the perch easily, but don't do that just yet.
    -Undo the front leaf bolt and then lift the leaf up and out.
    -Do the leaf removal in reverse on this side, then do the other side.
    -Once both leafs are back in and tight, install the new shocks.
    This is all from memory, so I could be wrong.
    CygnusX191 and Sociopenguin like this.
  19. Jul 27, 2023 at 5:38 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Step one. Hose all bolts down with penetrant. Everyday, for like a week before you try it. And try the front hanger bolts first.
    They will be the ones that fight if any do. Might as do a ubolt flip kit while youre in there as well.
  20. Jul 27, 2023 at 8:44 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You forgot the part where you bring the cup full of grease and absolutely slather those bushings before you slide them in
    Support the flip kit
