Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Mar 11, 2019 at 7:22 AM
    #8181
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  2. Mar 11, 2019 at 7:29 AM
    #8182
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    CygnusX191 likes this.
  3. Mar 11, 2019 at 7:30 AM
    #8183
    uploadadventure
    Dixon, Mo
    Lol
    Yeah. I went through to page 3. Then the last one hahah
  4. Mar 11, 2019 at 7:38 AM
    #8184
    Tacomania
    Tacomania IG: _tacomania
    Crazy Mike
    86 4runner / 2016 SR5 Tundra
    For the battery to die that quick, you might have something thats drawing power when its not on... i understand it wasnt new, but it wasnt dying either
    G.T. and CygnusX191 like this.
  5. Mar 11, 2019 at 7:43 AM
    #8185
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Or a toasty alternator...
    Tacomania[QUOTED] likes this.
  6. Mar 11, 2019 at 7:45 AM
    #8186
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    First thing I did was to check to see if I left anything on. I did not see anything. Drove it yesterday just fine.
    Would an alternator go out after 40,000 miles? I guess I'll find out. If I can't start it after work thats a pretty good indication that the alernator didn't charge it on my morning commute.
    CygnusX191[QUOTED] likes this.
  7. Mar 11, 2019 at 7:48 AM
    #8187
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Just went out and truck is dead. won't start. So what do you guys think? Battery or altenator?
  8. Mar 11, 2019 at 7:49 AM
    #8188
    G.T.
    G.T.
    CONUS
    Alternators are sometimes bad right out of the box. But before spending loot check your fuse box. I had a similar issue and it turned out that “ignition #2” fuse had blown.
  9. Mar 11, 2019 at 8:08 AM
    #8189
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Just checked every single fuse using a multi-meter and everything checked OK
    G.T.[QUOTED] likes this.
  10. Mar 11, 2019 at 8:12 AM
    #8190
    Wildwilly
    Wildwilly Well-Known Member
    David
    Southern illinois/ metro east STL area
    2015 DCSB SR5
    -LT -pelfreybilt Armor
    just borrow my truck...
    the only catch is you have to smuggle me with you, and call my wife and work and tell them i have been kidnapped so I don't get fired for not showing up for an entire weekend.
    HIYota, CygnusX191, Tacomania and 2 others like this.
  11. Mar 11, 2019 at 8:13 AM
    #8191
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    So I just called Toyota service and they said if there isn't a "check charging system" light on the dash then theres nothing wrong with the altenator. so I guess I'm gonna go buy a LAPS battery.
  12. Mar 11, 2019 at 8:54 AM
    #8192
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    So ran over to Autozone and bought a Duralast Gold. I guess we'll see what happens over the next couple days. If its truly a charging issue. Do you think I'll see problems by Wednesday? If I do I'm probably going to have to abort the trip.
    EDIT: Also bought a set of jumper cables...
  13. Mar 11, 2019 at 9:53 AM
    #8193
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Water can foul an alternator too, even if it's "good".
    Of course Toyota would say "well if the light isn't on then it's fine" regardless of the problem. :frusty:
  14. Mar 11, 2019 at 9:55 AM
    #8194
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I mean I just asked his opinion over the phone. My real question to him was if the alternator is covered under the powertrain warranty. That's when he was like "its probably the battery"
  15. Mar 11, 2019 at 1:43 PM
    #8195
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    So I found this old battery tester. It's basically a volt meter with a bunch of resistance so you can put a load on the battery and watch to see if the alternator kicks. So I hit the switch and i can see the battery instantly drop down to 12.2 volts and then as the alternator kicks in it comes back up to 13.4v. So i know my alternator is working. The question still remains if its putting out enough to keep the battery charged.
    EDIT: It would be interesting to perform this test on another 3rd gen to see if the results are similar. Any volunteers that can come over before wednesday?
  16. Mar 11, 2019 at 1:50 PM
    #8196
    G.T.
    G.T.
    CONUS
    Throwing stuff at the wall, but could it be a parasitic drain from an accessory? Some time I drive through stuff that makes me cringe a bit worried that I’ll screw some wiring up or something.
    CygnusX191, Tacomania and HIYota like this.
  17. Mar 11, 2019 at 1:53 PM
    #8197
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I thought about that too and I appreciate the idea. Since I created my RTMR, ALL my accessories and aftermarket switches now go through that RTMR box. I tripped the breaker on it and hooked up my multi-meter on either side of the breaker to determine if any amperage was going to the box and it never even wiggled off 0. So I don't think that thing is pulling power, either way I'm going to leave it tripped until I need it.
  18. Mar 11, 2019 at 2:47 PM
    #8198
    uploadadventure
    Dixon, Mo
    I might be able to stop by tomorrow. If needed
    mcharfauros likes this.
  19. Mar 11, 2019 at 3:04 PM
    #8199
    uploadadventure
    Dixon, Mo
  20. Mar 11, 2019 at 8:05 PM
    #8200
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Who else is coming from St. Louis to Winrock with @G.T. ?
    Looking forward to getting away for a bit. :oops:
