Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Apr 12, 2019 at 3:53 PM
    #9201
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Sold
    CygnusX191 and Thtguyrandy like this.
  2. Apr 12, 2019 at 4:07 PM
    #9202
    G.T.
    G.T.
    CONUS
    Hop on eBay and look for Tacoma front spindles. Here’s the secret, if they are factory spindles then you can use them regardless if they are off of a 2wd or 4wd as long as it was a six lug truck. These spindles are identical from 2005 to current. More often than not what’s going to be available are take offs from lifted prerunners using taller spindles.
    I bought a set that way and let Austin weld the TC gussets that allow for a sway bar because they have additional weld and gusset points.
  3. Apr 12, 2019 at 5:21 PM
    #9203
    NamelessTaco
    NamelessTaco Well-Known Member
    Jeremy
    Washington MO
    N/A
    I could easily weld that up, wouldn't be that hard at all really
  4. Apr 12, 2019 at 5:29 PM
    #9204
    mcharfauros
    MO
    Dumb Truck Thangs
    sweet! how much? seriously gonna check on a set of spindle gussets from Total Chaos
    CygnusX191 likes this.
  5. Apr 12, 2019 at 6:17 PM
    #9205
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Well you got a welder? Had to sell mine cause of a failure doing Hot Shots business, if not my brother in law has one I can use. And I would only ask for the gas, I wouldwou charge members. I like welding to much to charge friends, unless course it's a weekend type job! Lol, now I realize saying I could weld that without having a welder sounds stupid, but also think of it this way. I've welded steel beams that support cranes, roofs bridges girders an massive stuff most would be like hell naw! So welding something important like that to some is scary. Kinda what I meant by that statement.
    Red Demon, CygnusX191 and mcharfauros like this.
  6. Apr 12, 2019 at 6:26 PM
    #9206
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    This is the unit I used to have.
  7. Apr 12, 2019 at 6:37 PM
    #9207
    mcharfauros
    MO
    Dumb Truck Thangs
    Good stuff, don’t have a welder but could see about getting you some gas, what kind of mix would you need. My knowledge of welding is about as much as.....real don’t know much:rofl:
    CygnusX191 and Tacomania like this.
  8. Apr 12, 2019 at 6:38 PM
    #9208
    Wildwilly
    Wildwilly Well-Known Member
    David
    Southern illinois/ metro east STL area
    2015 DCSB SR5
    -LT -pelfreybilt Armor
    I need to do mine as well. I already have gussets I just never got around to welding. I guess its time to get it done. i'm willing to make mine a trial run, if they turn out good I could take care of yours if you haven't already done them by then. no charge, just an IOU, im sure at some point ill need help with some things.
  9. Apr 12, 2019 at 6:39 PM
    #9209
    mcharfauros
    MO
    Dumb Truck Thangs
    Roger that, sounds good
  10. Apr 12, 2019 at 6:41 PM
    #9210
    Wildwilly
    David
    2015 DCSB SR5
    im going to have to get real sweet with my wife so I can take over the garage hopefully within the next couple of days to get started. ill keep you updated. :welder:
    CygnusX191, mcharfauros and Tacomania like this.
  11. Apr 12, 2019 at 6:49 PM
    #9211
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    If JT doesn't mind could weld up both sets at his place on Modday. Give me a chance to throw sparks again, once you do it,its a thing you start to miss. I'd throw sparks on scrap at home for fun, for me its therapeutic more than a hobby. Getting burned wakes you up better than coffee! If you don't mind waiting a bit Wildwilly, I got gas in my tank to use up, its almost empty so using it up would be fine with me, then i could swap to a full one.
    mcharfauros likes this.
  12. Apr 12, 2019 at 6:50 PM
    #9212
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Candy Is dandy but liquor is quicker!
  13. Apr 12, 2019 at 6:53 PM
    #9213
    Wildwilly
    David
    2015 DCSB SR5
    :rofl: unfortunately have to stick to the candy..she's a bit pregnant
  14. Apr 12, 2019 at 6:54 PM
    #9214
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Uhmm, better start doing dishes an rubbing that Baby belly!
  15. Apr 12, 2019 at 6:55 PM
    #9215
    Wildwilly
    David
    2015 DCSB SR5
    took less than I thought, she just gave me the green light!
  16. Apr 12, 2019 at 6:56 PM
    #9216
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Wow, what did you do give her ice cream an do the ohhhhh sweetheart routine?
  17. Apr 12, 2019 at 6:58 PM
    #9217
    Wildwilly
    David
    2015 DCSB SR5
    im "working" so just a text :notsure: not sure what happened
  18. Apr 12, 2019 at 6:59 PM
    #9218
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Your not home yet, then you'll find out the terms an conditions for the agreement!
  19. Apr 12, 2019 at 9:36 PM
    #9219
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Snap on? That’s an expensive unit I bet.
  20. Apr 12, 2019 at 9:54 PM
    #9220
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Uhmmmm yesh was 3200 bucks
