Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. May 13, 2019 at 11:32 AM
    G.T.
    G.T.
    CONUS
    Harrop elockers are better.
    Tacomania, HIYota and mcharfauros like this.
  2. May 13, 2019 at 11:46 AM
    Thtguyrandy
    Thtguyrandy Thtguyrandy
    randy
    Stl,Missouri
    13 dcsb
    Total Chaos +2 LT 2.5 Kings front/rear Dakar leaf pack
    So switch to elockers. $26xx.xx isn’t bad (after core refund ). Be better if they throw in air compressor!
  3. May 13, 2019 at 11:52 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Meh. Air lockers leak pretty often. Id get e locker or a detroit style. Keep it simple.
  4. May 13, 2019 at 11:52 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Why is Harrop better than ARB? Or is it more of a Electronic better than air?
    CygnusX191 and Willy224 like this.
  5. May 13, 2019 at 1:30 PM
    robie_0n3
    robie_0n3 Well-Known Member
    David
    Scott AFB, IL
    2018 Tacoma TRD Off Road
    It was nice meeting everybody at Mod Day. Went home and measured from ground to fender. 2" of lift all around and couldn't be happier. Definitely got some Taco Lean going on, so ordered a 1/4" spacer from Head Strong Off Road.
    Also, Scott AFB Firestone wouldn't do my alignment, so going off base, to Carl's 4WD after someone recommended that shop to me.
    Willy224, CygnusX191, 95tojo and 3 others like this.
  6. May 13, 2019 at 1:39 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    You still have taco lean even though the 6112's were adjusted differently? Didn't they send you the shocks so that the driver side was set to 5th notch and passenger was set to 4th notch?
    CygnusX191 likes this.
  7. May 13, 2019 at 1:42 PM
    robie_0n3
    David
    Scott AFB, IL
    Yep. They're definitely set 5/4. Thought the lean would have been taken out with that adjustment.
  8. May 13, 2019 at 1:44 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    That's crazy. I have bilstein 6112, both set to 5th notch and a 1/4" spacer on driver and it sets perfect.
  9. May 13, 2019 at 1:46 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Why wouldn’t they do it? They did @mcharfauros truck and his stuff definitely looks like it’s not stock suspension.
    Tacomania, CygnusX191 and mcharfauros like this.
  10. May 13, 2019 at 1:51 PM
    robie_0n3
    David
    Scott AFB, IL
    Hopefully when this spacer comes in, I'll be good to go. Didn't think to get that before, because I thought the 5/4 setting would do it.
    He asked why I needed an alignment, and I said because my truck is a year old, and I upgraded to bigger shocks and struts. Didn't say a word about lifting or anything. Told them I upgraded to a better set, and the guy said since my ride height changed, they can't work on it... Even still, I'm close enough to the TRD Pro in height that they could adjust me there.
    Tacomania and CygnusX191 like this.
  11. May 13, 2019 at 1:53 PM
    95tojo
    95tojo Well-Known Member
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    Looks like they are maxed out on caster. Anymore and they said it would affect the toe.
    CMC it is. :playball:
  12. May 13, 2019 at 1:55 PM
    95tojo
    Jared
    So IL
    So the tire shop wont align a vehicle if it's been lifted ??? That dont make sense
    CygnusX191 and robie_0n3[QUOTED] like this.
  13. May 13, 2019 at 1:57 PM
    robie_0n3
    David
    Scott AFB, IL
    Exactly. I asked them what the ride height had to do with anything...
    I mean, I understand that if it's lifted too high, the LCA's can only move so far, and they may not be able to get back to spec... but to not even look at it, and tell me you can't do it? Sure, I'll take my money to a shop that wants it...
  14. May 13, 2019 at 2:03 PM
    G.T.
    G.T.
    CONUS
    Wait, what?
    I will, as I’ve learned the hard way that these air lockers are only worth the solenoids and I hate chasing leaks.
    ARB only makes air lockers, Harrop only makes elockers. I’m over air lockers and when the budget balances mine will be swapped.
    I forgot, did you do an upper control arm swap? If not, that’s likely why as your new suspension would put the ball joint too far out of center at standing ride height. Large corporations don’t like to muck about with things like that.
    CygnusX191, mcharfauros and 95tojo like this.
  15. May 13, 2019 at 2:08 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I have since been corrected.
  16. May 13, 2019 at 2:10 PM
    robie_0n3
    David
    Scott AFB, IL
    No, I didn't do UCA's. dammit, more stuff to buy... lol
  17. May 13, 2019 at 2:47 PM
    NamelessTaco
    NamelessTaco Well-Known Member
    Jeremy
    Washington MO
    N/A
    I've yet to get my truck bro and I'm already knowing that the list of parts will never end!
  18. May 13, 2019 at 2:47 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    FTFY
    Heck yes we’re coming. I planned that shit out man.
  19. May 13, 2019 at 2:53 PM
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    I can't man, sorry! I'm looking forward to the day I hang my keys up from the OTR life.
  20. May 13, 2019 at 2:56 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    Damn shame :anonymous:
