Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Sep 27, 2019 at 6:00 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    You can take me off the list. I have to be back Sunday by 10:30am to get ready for work and SMORR is just too far away to try and wake up early and get back in time. I think me and some friends may just hit up some local places Saturday.
    CygnusX191 and G.T. like this.
  2. Sep 27, 2019 at 6:15 AM
    G.T.
    G.T.
    CONUS
    TacoSam556, Tacomania and CygnusX191 like this.
  3. Sep 27, 2019 at 7:00 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    :rofl::rofl::rofl:
  4. Sep 27, 2019 at 7:06 AM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Went in for an oil change yesterday and got it back with the skid plate in the bed instead of under the truck.
    Tacomania, 95tojo, G.T. and 3 others like this.
  5. Sep 27, 2019 at 7:09 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    where did you go in for it at?
    is it the stock plate or aftermarket custom?
  6. Sep 27, 2019 at 7:16 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Whereat?
  7. Sep 27, 2019 at 7:23 AM
    G.T.
    G.T.
    CONUS
    It has a service access hole, doesn’t it?
  8. Sep 27, 2019 at 7:32 AM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    It is a shop in Starkville MS
    Aftermarket plate but it has a big ass hole to drain oil:IMG_20190927_092030032_HDR.jpg
    First time i got the truck back they told me I was all good to go and I went out to check the skid after I saw them taking it off in the shop and it was sagging on one side, so I checked it and only the passenger front bolt was in, the other 2 were missing. I don't want to find out what would happen if the front of that thing came loose while I am driving so I went back In and asked them to please put the other two in.
    They brought it in and out again and when I checked it the two nuts were just sandwiching the splash pan and skid , and not supporting them from the cross member like the third nut was, and the bolts were missing washers. I brought the guy out to show him and after commenting how if he knew the skid would be this big a pain they wouldn't have done it, and me showing him how you don't have to remove it to change oil, they brought it in again and I followed and figured out the reason they couldn't get it back correct is 3/6 nuts up front had clips broken off of them:
  9. Sep 27, 2019 at 7:33 AM
    mrb1218
    mrb1218 Afterburner
    B
    Albuquerque
    19 Cement Tacoma MT DCSB || 18 White T4R ORP Non-KDSS
    since there are no DT's in MO, where do you guys normally go for tires/wheels work stuff?
    CygnusX191 likes this.
  10. Sep 27, 2019 at 7:37 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i think i have a couple of those broken or stripped up front on my stock plate too, i was checking it out underneath for removal to get powder coated, since I have never taken that plate off myself ever i wasn't sure how many bolts are in but a couple are missing for sure
    that would not be good for it to fall off while on the highway for sure!
  11. Sep 27, 2019 at 7:38 AM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    They thought they had to take it off to get the oil filter I think. When I showed them how you get it from the wheel well I was told "man ain't nobody tryin to do all that" I had to refrain from a response to that...
    Definently learned my lesson to show the tech to use the big ass hole with the drain plug above it to drain the oil and access the filter from the wheel well... If I ever take it in to get an oil change again
    CygnusX191 and GQ7227 like this.
  12. Sep 27, 2019 at 7:44 AM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    Yes best case it would just hang down and shoot Sparks everywhere, but id be worried it would catch on something and turn it into a big lever and break the rear bolts and do some seriuis damage under the Tacoma or the vehicle behind me
    CygnusX191 and GQ7227[QUOTED] like this.
  13. Sep 27, 2019 at 7:44 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how often do you get it changed
    my range is from 3k to a bit less than 5k if those miles have been mostly highway
  14. Sep 27, 2019 at 7:56 AM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    I try to do every 3k this one was closer to 4 becuase I have been delaying it and I put on about 5k in a month going new Mexico to Houston to Mississippi to Missouri and back to Mississippi
  15. Sep 27, 2019 at 8:06 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i know that @Shellshock does not like that interval lol
    the guy who drives a lot...
    uploadadventure likes this.
  16. Sep 27, 2019 at 8:14 AM
    Shellshock
    Iowa
    shortest interval I’ve done lately was 8,000 and that’s only because I had a 4,000 mile trip coming up and didn’t want to find some place to f it up along the way.
    im typically in the 10-12,000 range
  17. Sep 27, 2019 at 8:20 AM
    G.T.
    G.T.
    CONUS
    bet you’ll do it yourself from now on. I’ve never met an oil change jock that knew anything about cars.
  18. Sep 27, 2019 at 8:27 AM
    95tojo
    95tojo Well-Known Member
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    I used to do 10k oil changes on my 3rz with conventional oil :rofl:
    I think longest I went was 13k. Haaaaated changing that oil filter. Man those motors are tough. :fistbump:
  19. Sep 27, 2019 at 8:31 AM
    Shellshock
    Iowa
    I had an oil change done AT TOYOTA and they took off my OEM TRD PRO skid instead of using the access panel....
    ...and then failed to put it back on right
    after that and the fact they severely over torqued both the canister, canister drain and oil drain I was done with the dealer service department.
  20. Sep 27, 2019 at 8:38 AM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    Yes I should have. Biggest thing keeping me in what to do with the used oil.
    What do you guys do with it?
    GilaTrails, CygnusX191 and GQ7227 like this.
