Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Feb 10, 2020 at 12:00 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Second this ^ early October too.
    TacomaDad18, 95tojo and CygnusX191 like this.
  2. Feb 10, 2020 at 12:05 PM
    Shellshock
    Iowa
    Basically anytime after September 1 and before it snows lol
  3. Feb 10, 2020 at 2:13 PM
    TacoSam556
    TacoSam556 Well-Known Member
    Sam
    IN to MO and back to IN
    2010 Speedway Blue Sport
    OME BP-51s & MD Dakar Leaf Pack Swaybar delete Rear Diff Breather Extension DBCustomz grill with TacomaPros Raptor Light Kit Rago Fab: Relay holder, ditch light brackets, tailgate antenna mount Baja Designs: Squad Sports Fog & Ditch Light, 40" S8, AJT Designs: battery clamp, shift knob, key fob, and climate control knobs MESO: gasshole, switchable maps, red dome AeroTurbine 2525 Prinsu Cabrac Direct Igniter 6' LED whip OEM Audio+ Total Chaos: UCA's and Alignment cam tab gussets DuroBump front bump stops
    My parents are headed to Flagstaff/Sedona the week leading up to the 4th. I’m hoping to go, but it’s going to depend on where I’m at with vacation allotment/job. Had an interview in Indy this morning that sounds promising. Would put me mostly out of striking distance for mod days without planning, but I think would be better for state of mind at this point.
  4. Feb 11, 2020 at 5:42 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
  5. Feb 11, 2020 at 6:00 AM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    :boink:
    CygnusX191[QUOTED] likes this.
  6. Feb 11, 2020 at 7:03 AM
    TacomaDad18
    TacomaDad18 overlanderrr asf
    1uz 2018 SR5
    Hard round things Soft round things Metal bouncy things Shifty thing Locking thing
    Spent an hour tracking down why my locker wouldn’t turn on.... loose wire because dumb shits do not take pride in their work. Didn’t even get a full crimp when they spliced their power wire into on of mine (which is wrong I’m pretty sure) that go to my lights.
    Literally stopped working one day. Locker switches lit up but no compressor kicking on. Figured it had to be electrical... I found it, soldered the connection and heat shrinked it so it will not come loose again.
    And found out that my license plate light (has not been working) was damaged when they installed my bumper. They literally tried to get the bulb socket to stick to the license plate light assembly with some sort of rubberized shit. AHH frustrates the hell out of me..... now trying to get a replacement
    Why is it so hard to do your job correctly and take pride in your work? I just don’t understand.
    Arb was installed at Pur performance, yes they came highly recommended. They suck. They also snapped a bolt, rtv’d it back on and sent it on its way- yes it leaked- yes they said I was rushing them- no I was not. They were not telling me why it took 3 days longer than expected.
    Anyway have a good day all! That is my rant for the day.
  7. Feb 11, 2020 at 7:09 AM
    Shellshock
    Iowa
    Every time I hear about someone having work done at a shop, I find less and less reasons to do so
    95tojo, CygnusX191, kmwilt and 2 others like this.
  8. Feb 11, 2020 at 7:16 AM
    TacomaDad18
    1uz 2018 SR5
    Yup, all because I was nervous about putting a hole in my brand new trucks diff... if a shop can do this kind of work, hell I’ll do it on my own. I fully intend on putting gears in my truck (which I’ve done before) just usually don’t have time. After all the screw ups from shops, I’ll make time.
    Makes you wonder if I caught this, what happens to all the other thousands of vehicles they work on... what does their crap work look like on theirs.
  9. Feb 11, 2020 at 7:20 AM
    Shellshock
    Iowa
    You can do a trial run putting 5.29s in @Cav_BluTRD
  10. Feb 11, 2020 at 7:21 AM
    uploadadventure
    Dixon, Mo
    :spy:
    TacomaDad18, CygnusX191 and Willy224 like this.
  11. Feb 11, 2020 at 8:02 AM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    This why I avoid shops as much as possible unless it's MAJOR work that needs to be done and if I don't have the right equipment to do it. Learned that lesson when my ford was going through coils like crazy and it turned out my head gasket was literally in pieces. The shop I was going to just kept replacing the coils and it qould fix the problem for a few days then I went to a shop that a buddy of mine worked at and he found out the issue the day after I dropped it off
    Edit: I didn't reqlly know how to work on vehicles at the time but now i know better :D
  12. Feb 11, 2020 at 9:00 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's why we have Modday.
    Also everyone recommends Put performance, went there once with the Lj and said nope.
    Sasquatch3153 and TacomaDad18 like this.
  13. Feb 11, 2020 at 9:25 AM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    I've learned a bunch over the years from all the mod days starting back in Cali with my buddy @PreRunnerSeth. I am willing to attempt most mechanical things. There are things I'm not willing to touch on the truck, mostly electrical crap or welding. Those I suck at, especially electrical. Back on my old truck my stereo wiring was so bad it killed my battery consistently and ended up being convinced it was my alternator by a shop. It was a good $$ lesson once I was able to get it looked at by a family friend.
  14. Feb 11, 2020 at 9:32 AM
    TacomaDad18
    1uz 2018 SR5
    I’ve done it several times, not worried about the Install. It’s the time. I had to literally schedule the tacobox install with the wife lol
  15. Feb 11, 2020 at 9:34 AM
    Shellshock
    Iowa
    I wish I had a tacobox :drool:
    also that RCLT kit is pretty sweet
  16. Feb 11, 2020 at 9:38 AM
    TacomaDad18
    1uz 2018 SR5
    man I’m waiting. I keep messaging them about the rclt to find out price. If it’s between 4-5k it’s worth it to me. Any more- negative.
  17. Feb 11, 2020 at 9:49 AM
    HIYota
    Angel
    That's my guess on their lower end kit without their optional upgrades.
  18. Feb 11, 2020 at 9:52 AM
    TacomaDad18
    1uz 2018 SR5
    Im hoping so. I can also see it being 7-8k easily. There’s like 200+ parts to the kit. Plus the mar rack which could easily be 2k by its self
    HIYota[QUOTED] likes this.
  19. Feb 11, 2020 at 10:07 AM
    HIYota
    Angel
    If it's as good as it's being hyped up to be I can see it costing upwards of $10k for the best kit. You'll have close to capability of sas with much less fabrication time/effort.
    TacomaDad18[QUOTED] likes this.
  20. Feb 11, 2020 at 10:13 AM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    The most technical things I've done so far was outting in a transmission in and putting in/taking out an engine out of my buddy's car like 3 times now lol and me and him did a head gasket replacement on a Saturn which was a pain, it was an experiment to see if we could do it successfully and it was, just had a pretty small leak lol
    HIYota[QUOTED] and TacomaDad18 like this.
