TacoSTIG: PNW MT Build
Discussion in '2nd Gen. Builds (2005-2015)' started by TacoSTIG, Jan 19, 2015.
  1. Aug 14, 2015 at 3:29 PM
    #181
    TacoSTIG
    TacoSTIG [OP] Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Honestly, your 285 MT's will likely measure out just shy of the 295 AT's.
    I've been trying to make smart choices with the truck and decided that 35's would be mostly an aesthetic decision. To clear 35's I'd have to massacre my fenders which in turn makes the tires look small again... Some 35's can look just as small as 285 depending on the fenders. I've realized that it becomes a give or take game of wheel gap which makes or breaks the look. Still, the additional clearance gained with a bigger tire cant be argued with, but I don't need it... yet.
    At least that's what I'm telling myself now.... :anonymous:
  2. Aug 14, 2015 at 4:22 PM
    #182
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    yeah they will come just about the same height as BFG's run small.. Only time will tell :)
  3. Aug 16, 2015 at 6:57 PM
    #183
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    So after few days post lift install I entered the "what's that new sound?" game.
    Normally these are fairly easy to figure out but I must admit, this one has left me utterly baffled.
    The sound appears to be coming from under the passenger side rear seat intermittently on acceleration from a stop but more often when making abrupt right hand turns.
    It's always the same frequency, pitch, and tone. The only variable is it's duration...
    The sound...
  4. Aug 16, 2015 at 6:59 PM
    #184
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    oh wow.. hmm.. Nothing sliding around under the rear seats? Maybe a loose socket set? Ill have to keep thinking on that
  5. Aug 16, 2015 at 7:01 PM
    #185
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Sure sounds like it but I've since taken everything out of the truck. I keep wanting to blame the ebrake cables doing something weird but each time I check them they're secure like everything else down there. I'm perplexed... If only I had huge tires to blame, I'm still sporting the stockers.
  6. Aug 16, 2015 at 7:03 PM
    #186
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    It really sounds like your tires are rubbing on the fender plastic or something is moving. Did it happen right after you put the lift on?
  7. Aug 16, 2015 at 7:09 PM
    #187
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Didn't make a sound until a day after I unloaded 200lbs from the bed, which was a few days ago. So the rear is a tiny bit higher, hmm
  8. Aug 16, 2015 at 7:45 PM
    #188
    Peewee
    Peewee Well-Known Member
    Casey
    Seattle, WA
    2008 TRD DCSB
    have you had someone in the vehicle with you to confirm where the sound is coming from? and the sound isn't just in your head? lol. But seriously, if someone else is in the vehicle, they can crawl around and see if they can identify the source or at least the direction of the sound, being the driver makes it difficult to pinpoint the sound direction as you have to stay in one place.
  9. Aug 16, 2015 at 7:59 PM
    #189
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Hmm.. that is really weird. Ill keep thinking
  10. Aug 16, 2015 at 8:26 PM
    #190
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    So I just removed my ebrake chassis hangers thinking I was somehow binding the cable under 'shockless' rear suspension travel.
    Went for a drive, still happening... wtf.
    Pissed I grabbed a few tools and ripped into the back AC half seats. For one I wanted to know how much space I had under the plastic liners for a potential OBA install location and two, I hoped to find something stupid.
    I sadly concluded that there's not enough room for an OBA setup but I did indeed find something stupid! There was a rouge splined lugnut sitting in a rectangular channel under the seat tray. It let the lug roll back and forth in one axis which is why the sound was perfectly consistent.
    The spline drive symphony has since been canceled.:sadviolin:
  11. Aug 16, 2015 at 8:50 PM
    #191
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Good and bad :/
  12. Aug 16, 2015 at 9:01 PM
    #192
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    True, just means it's time to get creative. Glad you were right about "something under the seat". Didn't know I had even more room under the tray that I cleaned out. Swore the sound was coming from under the truck, guess this is why I'm a painter, not a sound engineer.
  13. Aug 16, 2015 at 9:06 PM
    #193
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I just couldn't think of anything that could make that sound under the truck, it definitely sounded like something rolling around under it
  14. Aug 16, 2015 at 9:07 PM
    #194
    Peewee
    Casey
    Seattle, WA
    2008 TRD DCSB
    Hey at least it means you're not going crazy and hearing things in your head.
    TacoSTIG[QUOTED][OP] likes this.
  15. Aug 16, 2015 at 9:13 PM
    #195
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    hah, this is only the beginning of the sounds I'll be hearing.
  16. Aug 16, 2015 at 10:08 PM
    #196
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    thats so true hahaha
  17. Aug 17, 2015 at 10:56 AM
    #197
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    well... I got an ENCORE on my way to work this morning.
  18. Aug 17, 2015 at 11:01 AM
    #198
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    In better news I got a call from Discount Tire this morning, fresh rubber comes in mid October!
  19. Aug 17, 2015 at 11:02 AM
    #199
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Noooooo thats so far away.. Pavement princess until then
  20. Aug 17, 2015 at 11:23 AM
    #200
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    These stockers haven't stopped me in the past. But first things first I should probably get my shocks on before I hit the trail.
    Currently, I've gone full turtle.
    :turtleride:
