TacticalBacon13's camp
Discussion in 'North East' started by TacticalBacon13, Oct 13, 2011.
  1. Jan 4, 2012 at 11:17 AM
    #2481
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Front rubs the pinch weld, thats it. there's nothing else to rub against up there :p
    They're Bighorns. I just found out that there are TrXus in this size, but measure 32.7" instead of 33.3" like the bighorns. Had I known that I probably would have bought the TrXus', cause them things are badass.
  2. Jan 4, 2012 at 11:28 AM
    #2482
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    That's cheating, where's your front fender flares?
  3. Jan 4, 2012 at 11:30 AM
    #2483
    pittim
    Pennsyltucky
    Boujee Prius
    in my parents garage :cool:
    once its gets warm the rears are coming off.
  4. Jan 4, 2012 at 12:12 PM
    #2484
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I was looking at the KM2s with a little custom siping. I hear that they are pretty tall though.
  5. Jan 4, 2012 at 12:16 PM
    #2485
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I don't know if you saw it posted in the garage but I'm putting TRD mesh in the prototype.:cool:
    I'll bring it along on Sat.
  6. Jan 4, 2012 at 12:16 PM
    #2486
    Enigmaaron
    PA
    1st gen superiority
    Running a wheel spacer/adapter at all? You gotta be to not rub the frame up front right?
  7. Jan 4, 2012 at 12:17 PM
    #2487
    JDMcQ
    That's cool, but I have to mount my Devil Horn in there. Perhaps you can make another with the grill I am bringing along.
  8. Jan 4, 2012 at 12:20 PM
    #2488
    pittim
    Pennsyltucky
    Boujee Prius
    Same height as bighorns, 33.3"
    No spacer. They only rub at full lock, but full lock puts a lot of strain on the PS pump, so i figure its another reason as to not turn that hard :cool:
  9. Jan 4, 2012 at 12:23 PM
    #2489
    JDMcQ
    The 255s are my cheapest option right now (in larger sizes) as I can either use my existing wheels (rather not) or the 4Runner wheels (unless Larry buys them. It would also require the most work for proper fit.
  10. Jan 4, 2012 at 12:26 PM
    #2490
    pittim
    Pennsyltucky
    Boujee Prius
    If you're set on KM2s, the 285s run 33.1", so you're gonna have to do pretty much the same amount of work to get them to fit compared to the 255s.
  11. Jan 4, 2012 at 12:27 PM
    #2491
    JDMcQ
    If I go with the 285s I would get an AT. Maybe the General AT2.
  12. Jan 4, 2012 at 2:37 PM
    #2492
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    XBause son!
  13. Jan 4, 2012 at 3:18 PM
    #2493
    Enigmaaron
    PA
    1st gen superiority
    Welp, looks like my clutch is done. Was slipping bad above 2.5-3k rpm in gears 3-5 after getting past an accident on the way home. Babied it the rest of the way and then gave it a little gas when I was almost home and it didn't slip again. But I think I should probably get it taken care of ASAP. Easier or harder than doing the timing belt/water pump?
  14. Jan 4, 2012 at 3:26 PM
    #2494
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Did the clutch on my 87' in my garage with a buddy... not too bad.
    Never did the 3.4 5speed. but you'll be dropping the trans & t-case together so make sure you've got good jacks & stands and a buddy does help...
  15. Jan 4, 2012 at 3:49 PM
    #2495
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    How much lift you have john? I have 255s n they're a great tire. Siping them is gonna cut the mileage off of em
  16. Jan 4, 2012 at 4:31 PM
    #2496
    TacticalBacon13
    TacticalBacon13 [OP] Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    name Yo
  17. Jan 5, 2012 at 7:20 AM
    #2497
    TacticalBacon13
    Dunk
    Beech Creek
  18. Jan 5, 2012 at 8:16 AM
    #2498
    JDMcQ
    2.5-3"
    Most accounts say that siping increases the mileage due to running cooler. Not concerned about it though, I don't put that many miles on the truck anymore.
  19. Jan 5, 2012 at 8:35 AM
    #2499
    TacticalBacon13
    Dunk
    Beech Creek
    ben you alive?
  20. Jan 5, 2012 at 8:36 AM
    #2500
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    :eek:
    Wushup beash?
