TACUNDRA - 5.7L 3URFE swapped 2nd gen project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikieSwartz, Jan 13, 2019.
Will I end up with a functional 5.7L Tacoma?
  1. Yes. I watched you're video and I have faith in you.
    37.8%
  2. Probably. I mean, you already have a whole Tundra for parts.
    40.9%
  3. Maybe. If you're a Toyota tech and have an engineering degree.
    14.2%
  4. Probably not. If it was possible, other guys would already have it done.
    7.6%
  5. No. You're blowing smoke or you're delusional.
    7.3%
Multiple votes are allowed.
  1. Jul 27, 2020 at 10:31 PM
    #241
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    To do the swap, what would be the absolute minimal amount of other stuff to do to get the job done?
  2. Jul 31, 2020 at 9:44 PM
    #242
    Capt’nCrims
    Capt’nCrims Well-Known Member
    Lol good luck!! Me and my father in law, local 30 years mechanic with his own shop, have been talking about doing a 4.6/4.7 v8 or 5.7 v8 into my single cab 4x4 eventually. Originally planned on doing a simple 4.0 swap and change out from the 2.7 but hey if you’re going to do it might as well do it.
    gm full float is an excellent rear end if that’s what you’re still going with, have done a few projects with those and Dana fronts, mostly with old Chevy blazers though so was pretty much bolt on in that case. We haven’t gotten near as far into figuring out how to tackle it.
    Love to see where this goes for you we’re excited to get going on it ourselves but looking for a donor now. Cool to see someone else doing it and recording it.
    still might go with a 4.0 but he’s really trying to convince me on a tundra v8.
    JTFisherman and MikieSwartz[OP] like this.
  3. Aug 1, 2020 at 10:55 AM
    #243
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    For your 2.7, a fairly simple turbo install will give that engine loads of power. That 2.7 is a beast of an engine. Far stronger than the 4.0.
    4.0 is a super easy swap in. Since the chassis is the same.
    The 2UR(?), which comes in the 4Runner, is also a pretty easy swap in, since it has the 4.0 as well.
    Just some other options for you. Had you not thought about those. All up to your desires though. Carry on mate. :thumbsup:
    Capt’nCrims[QUOTED] likes this.
  4. Aug 23, 2020 at 3:52 PM
    #244
    MikieSwartz
    MikieSwartz [OP] 5.7L iForce V8 Tacoma : YouTube.com/WhipBash
    Carlisle PA
    Rolled 05 Tacoma 4x4 crew cab "Tacundra" + Rolled 96 Tacoma 4x4 Budget Build
    05 Tacoma: 37" Tires, Method bead-locks, Long Travel, King shocks, Custom fabrication, currently swapping in a 5.7L 3URFE Tundra V8 ! 96 Tacoma: Budget Build Lots of DIY !
    I'm still way behind on videos and to be honest, I haven't been working on this truck much at all this summer. The weather has been nice and I've had my son most of the time. So, we've been doing other things. But I still have a few episodes I haven't even edited yet. And I really want to get back to work on this project. My son went back to his mom's house now cause school is starting. So, I'll try to get back to it now!! And here's the new TACUNDRA video! Thanks for watching! https://youtu.be/VhTJ_y2Ev-E
  5. Aug 24, 2020 at 9:42 AM
    #245
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All of the thoughts of mine, have probably been taken care of by now, due to your early comments.
    Plans on wrapping that header, near the steering column?
    Curious if you bent some steel plate, or cut a piece of pipe in half for the needed crossmember notch?
    www.aceraceparts.com has very good V-band flanges. The weld area is higher away from the flange face, which helps prevent flange distortion. If you hadn't ordered them yet.
    Hawk373 likes this.
  6. Aug 24, 2020 at 9:47 AM
    #246
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Really anxious to see the next videos! I am sure that you are anxious to get it back together, as you are quite close.
    MikieSwartz[OP] likes this.
  7. Sep 21, 2020 at 2:56 PM
    #247
    MikieSwartz
    Carlisle PA
    I am but I have so much going on - its been hard to make time for this. But yeah, its close!
    Torspd[QUOTED] likes this.
  8. Sep 21, 2020 at 3:03 PM
    #248
    MikieSwartz
    Carlisle PA
  9. Sep 21, 2020 at 3:10 PM
    #249
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  10. Sep 22, 2020 at 5:07 AM
    #250
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ha! Well played. B&C get my votes. Whom I kidding, I'd party with all of them. :D
  11. Sep 22, 2020 at 5:43 AM
    #251
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Big projects take a lot of time. Especially when you're mainly a one man crew. :thumbsup:
  12. Jan 14, 2021 at 5:01 PM
    #252
    MikieSwartz
    Carlisle PA
  13. Jan 14, 2021 at 5:18 PM
    #253
    05Taco4x4
    2TR-FE Enthusiast
    Lookin good man, you'll be done in no time now that you've got over the schematic hump and burning solder
  14. Jan 15, 2021 at 7:33 AM
    #254
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have to watch in just a few.
  15. Jan 15, 2021 at 7:53 AM
    #255
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    So...so....close! Keep up the good work, Mikie!
  16. Jan 15, 2021 at 8:04 PM
    #256
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am going to hypothesize that an electric fan setup, is what you'll be using?
  17. Jan 19, 2021 at 10:20 AM
    #257
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Schwartz zombie???
  18. Jan 30, 2021 at 12:12 PM
    #258
    MikieSwartz
    Carlisle PA
    I was planning for an electric fan, but recently changed my mind. The sizing for everything is coming together really nice.
    05Taco4x4 and Torspd[QUOTED] like this.
  19. Jan 30, 2021 at 12:20 PM
    #259
    MikieSwartz
    Carlisle PA
    I forgot to post episode 34, but hopefully you guys are subscribed to the channel too. I just put episode 35 up. I realize the wiring is kinda boring, so I brought back the hot dancing Asian girls! (applause)
    I'm editing 36 now. And to be honest, the project is at a stand-still now due to something I just can't seem to figure out. As soon as I'm caught up, I'll be asking my viewers for help! So details are coming soon...
    https://youtu.be/oBEUNOAP_yI
  20. Jan 30, 2021 at 12:45 PM
    #260
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No clues to be found in the vids?
