TACUNDRA - 5.7L 3URFE swapped 2nd gen project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikieSwartz, Jan 13, 2019.
Will I end up with a functional 5.7L Tacoma?
  1. Yes. I watched you're video and I have faith in you.
    37.9%
  2. Probably. I mean, you already have a whole Tundra for parts.
    41.0%
  3. Maybe. If you're a Toyota tech and have an engineering degree.
    14.2%
  4. Probably not. If it was possible, other guys would already have it done.
    7.6%
  5. No. You're blowing smoke or you're delusional.
    7.1%
Multiple votes are allowed.
  1. Jan 30, 2021 at 3:04 PM
    #261
    Waasheem
    Waasheem
    2007 xrunner
    When you finish, you're going to work on a plug and play kit for the rest of us? Tools required: flat screwdriver, claw hammer, slip joint pliers. 3 hours of labor.
  2. Jan 30, 2021 at 3:06 PM
    #262
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I like where your head is.
    MikieSwartz[OP] likes this.
  3. Jan 30, 2021 at 4:14 PM
    #263
    MikieSwartz
    MikieSwartz [OP] 5.7L iForce V8 Tacoma : YouTube.com/WhipBash
    Carlisle PA
    Rolled 05 Tacoma 4x4 crew cab "Tacundra" + Rolled 96 Tacoma 4x4 Budget Build
    05 Tacoma: 37" Tires, Method bead-locks, Long Travel, King shocks, Custom fabrication, currently swapping in a 5.7L 3URFE Tundra V8 ! 96 Tacoma: Budget Build Lots of DIY !
    Not yet
  4. Feb 17, 2021 at 11:04 AM
    #264
    MikieSwartz
    Carlisle PA
  5. Feb 17, 2021 at 1:57 PM
    #265
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You've done an exceptional job with your wiring dope sheet. Bravo.
  6. Feb 22, 2021 at 5:44 PM
    #266
    MikieSwartz
    Carlisle PA
    Spoiler alert! It's ALIVE!!! I've got some editing to do! And still a lot more work ahead. But I wanted to share the news here first.
  7. Feb 22, 2021 at 5:57 PM
    #267
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    That's awesome
  8. Feb 22, 2021 at 6:32 PM
    #268
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    :ohsnap::101010::mudding:
    Torspd likes this.
  9. Feb 23, 2021 at 8:51 AM
    #269
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :woot: :woot: :cheers:
  10. Mar 2, 2021 at 11:06 PM
    #270
    MikieSwartz
    Carlisle PA
  11. Mar 2, 2021 at 11:11 PM
    #271
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    xxTacocaTxx likes this.
  12. Mar 3, 2021 at 4:20 AM
    #272
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Same here as of this morning. :redxfall:
  13. Mar 4, 2021 at 3:27 PM
    #273
    MikieSwartz
    Carlisle PA
    Sorry guys. I'm still figuring out YouTube. smh It will be viewable in 30 mins!
  14. Mar 28, 2021 at 10:59 AM
    #274
    MikieSwartz
    Carlisle PA
    Tacundra 38 - still troubleshooting - almost caught up with the videos. In realtime, the engine is running, but idles very high like 2000-2500 RPM maybe. I'm not going to start troubleshooting the high idle until the radiator is in. I made removable upper and lower rad supports. But I put the work on hold so I can spend some time catching up with videos. I want to get caught back up so my audience can assist with troubleshooting.
    I haven't got my rear driveshaft yet. I tried to put it in 4WD to back it out of the garage but the 4WD is not engaging AND then I noticed the right front wheel will not spin now. It must be a problem in the ADD.
    Thank you to everyone watching and encouraging me to stick with the project! Enjoy:
    https://youtu.be/bn4RgERxdO8
  15. Mar 29, 2021 at 3:33 PM
    #275
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tortoise wins the race my man. :thumbsup:
    That high idle, could be due to initial start-up. After having the battery disconnected for so long. Once coolant is in, and there aren't any bad CEL's it should lower.
  16. May 5, 2021 at 8:13 PM
    #276
    MikieSwartz
    Carlisle PA
  17. May 5, 2021 at 8:15 PM
    #277
    MikieSwartz
    Carlisle PA
    I think my kid really juices up the videos. I know he distracts from the actual project, but it adds character to the video. I hope some people agree.? TACUNDRA 40:
    https://youtu.be/DC7bxGYP3yU
  18. May 6, 2021 at 4:28 AM
    #278
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He add his own young flare. Most importantly, is the father-son interaction that you have and influence. :thumbsup:
  19. May 6, 2021 at 4:49 AM
    #279
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ahhh...when's the next vid coming out? Curious if that worked???
  20. May 26, 2021 at 5:41 PM
    #280
    05Taco4x4
    2TR-FE Enthusiast
