TACUNDRA - 5.7L 3URFE swapped 2nd gen project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikieSwartz, Jan 13, 2019.
Will I end up with a functional 5.7L Tacoma?
  1. Yes. I watched you're video and I have faith in you.
    37.9%
  2. Probably. I mean, you already have a whole Tundra for parts.
    41.0%
  3. Maybe. If you're a Toyota tech and have an engineering degree.
    14.2%
  4. Probably not. If it was possible, other guys would already have it done.
    7.6%
  5. No. You're blowing smoke or you're delusional.
    7.1%
Multiple votes are allowed.
  1. Feb 20, 2019 at 9:18 PM
    #101
    36tacundra
    36tacundra Well-Known Member
    I like your use of the Tacundra word. The 4.7 in the first gen I did will be a little less impressive next to the Tacundra 2.0 you will be doing, LOL! I also wanted to do this swap, but I haven't got a 5.7 yet. Looks like we will watch you first and see how it goes. I know that you will be successful. It is a matter of what will it take.
    lowtidejoe likes this.
  2. Feb 21, 2019 at 2:55 AM
    #102
    36tacundra
    When I watched the video, the plug on the firewall that had been torn apart, looked as though some of the wires had been pulled from the plug. Maybe they are not yet connected.
    dolbytone likes this.
  3. Feb 21, 2019 at 3:24 AM
    #103
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
  4. Feb 21, 2019 at 3:42 AM
    #104
    MeowListenHere
    MeowListenHere Well-Known Member
    Aric
    New Orleans
    2005 Tacoma TRD sport
    If you pull this off that will be amazing.
    MikieSwartz[OP] and DGXR like this.
  5. Feb 21, 2019 at 7:48 AM
    #105
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    i watched your updated video last night since Im subbed to you on youtube. Great vid.
    Have you since been able to get it started? Were the issues caused by the fuel being sent?
    Torspd likes this.
  6. Feb 22, 2019 at 6:24 AM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Try disconnecting the sending fuel line either at the tank and or engine bay. Then crank and see if any fuel comes out.
    05Taco4x4 and SaphiraTaco like this.
  7. Feb 22, 2019 at 12:53 PM
    #107
    ThomasMore66
    Dallas/Fort Worth & Durango
    And, we told you the best part of the videos...you forgot that. The girl.
    MikieSwartz[OP], Torspd and spitdog like this.
  8. Feb 25, 2019 at 3:55 PM
    #108
    MikieSwartz
    MikieSwartz [OP] 5.7L iForce V8 Tacoma : YouTube.com/WhipBash
    Carlisle PA
    Rolled 05 Tacoma 4x4 crew cab "Tacundra" + Rolled 96 Tacoma 4x4 Budget Build
    05 Tacoma: 37" Tires, Method bead-locks, Long Travel, King shocks, Custom fabrication, currently swapping in a 5.7L 3URFE Tundra V8 ! 96 Tacoma: Budget Build Lots of DIY !
    I haven't had time to work on it since that video. I have way too much going on. smh
  9. Feb 25, 2019 at 4:36 PM
    #109
    MikieSwartz
    Carlisle PA
    Hey guys. I know you're all eager for the 5.7 swap, but check out my 1st gen in this new video while you wait! :)
    https://youtu.be/ZR6xOE6txaI
    D2., bax and AMartin like this.
  10. Mar 5, 2019 at 11:33 AM
    #110
    MikieSwartz
    Carlisle PA
    I've got an update video for the Tacundra swap. Learned about inertia switches and Toyota's version called a "circuit opening relay". I bypassed that to make it run, but now I found a new problem. Nothing I can't handle - just part of the process of buying a wrecked donor truck. Video premiers at 5:30. https://youtu.be/uFYI-0KG7qQ
    bayrak, D2., Thebubble and 5 others like this.
  11. Mar 5, 2019 at 11:44 AM
    #111
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    nice man! I'm still sitting back waiting to see how the whole thing turns out....
  12. Mar 5, 2019 at 12:15 PM
    #112
    MrBrapp
    MrBrapp Active Member
    micah
    2016 trd sport, 03 trd, 01 taco
    to many
    so awesome, looking forward to watching your journey of the swap.
  13. Mar 5, 2019 at 7:16 PM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That was a good diagnostic find with the cam sensors wires.
    bax likes this.
  14. Mar 5, 2019 at 8:18 PM
    #114
    ToyotaRacingDev
    ToyotaRacingDev 425,000km
    London, Ontario
    2008 Tacoma TRD Sport
    Why don’t you put the wires back in the plug and test it?
    bax likes this.
  15. Mar 6, 2019 at 4:11 AM
    #115
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Where and when is truck nationals???
    ToyotaRacingDev and Taco critter like this.
  16. Mar 6, 2019 at 8:06 AM
    #116
    bax
    bax Well-Known Member
    Tyler
    Georgia
    Black 2015 DCSB TRD Off Road
    So cool getting to watch this progress in real time.
  17. Mar 6, 2019 at 10:12 AM
    #117
    TegoTaco
    Ontario, Canada
    Would consider a road trip with the family for that one. Lot of TW members attend?
  18. Mar 6, 2019 at 10:28 PM
    #118
    36tacundra
    Nice, wires pulled apart at the firewall. I would love to be there. I could give you a hand. I probably would not leave the garage though. You would have to remove me with Bertha and a restraining order, LOL. I just learned some lessons my self with the vvti cam sprockets on the 4.0. As it turns out the 03-04 toyota 4runner had a different design than 05 and up. It took more than a week for me to catch it.
    D2. and bax like this.
  19. Mar 26, 2019 at 2:04 PM
    #119
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    Anybody heard from him lately?
  20. Mar 27, 2019 at 6:52 AM
    #120
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I suspect that after you shoehorn a V8 into your Tacoma you forget about your friends/responsibilities for a while due to an erection lasting for more than four hours.
    /still no V8 in my Tacoma...
