TACUNDRA - 5.7L 3URFE swapped 2nd gen project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikieSwartz, Jan 13, 2019.
Will I end up with a functional 5.7L Tacoma?
  1. Yes. I watched you're video and I have faith in you.
    37.8%
  2. Probably. I mean, you already have a whole Tundra for parts.
    40.9%
  3. Maybe. If you're a Toyota tech and have an engineering degree.
    14.2%
  4. Probably not. If it was possible, other guys would already have it done.
    7.6%
  5. No. You're blowing smoke or you're delusional.
    7.3%
Multiple votes are allowed.
  1. Aug 9, 2019 at 3:27 PM
    #161
    MikieSwartz
    MikieSwartz [OP] 5.7L iForce V8 Tacoma : YouTube.com/WhipBash
    Carlisle PA
    Rolled 05 Tacoma 4x4 crew cab "Tacundra" + Rolled 96 Tacoma 4x4 Budget Build
    05 Tacoma: 37" Tires, Method bead-locks, Long Travel, King shocks, Custom fabrication, currently swapping in a 5.7L 3URFE Tundra V8 ! 96 Tacoma: Budget Build Lots of DIY !
    If that unbolts, I'm going to LOL at myself! No... I'm sure its welded together.
    05Taco4x4[QUOTED] likes this.
  2. Aug 9, 2019 at 3:28 PM
    #162
    MikieSwartz
    Carlisle PA
    I was warned about the mount brackets cracking at the frame... I should probably plate the frame before I weld them back in and the gusset the brackets too.
    Torspd[QUOTED] and bax like this.
  3. Aug 9, 2019 at 3:30 PM
    #163
    MikieSwartz
    Carlisle PA
  4. Aug 9, 2019 at 5:36 PM
    #164
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    It’s offset to the passenger side so the header pipe clears the steering shaft
    Torspd likes this.
  5. Aug 10, 2019 at 6:23 AM
    #165
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That was me. With your resourcefulness, I am sure you can get metal cheaper than buying the weld on plates. Easy enough for a person with the right tools and expertise to cut their own plates and weld.
  6. Aug 30, 2019 at 5:34 PM
    #166
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    After it’s all said and done! Looking forward to it!
    MikieSwartz[OP] and Coolerman like this.
  7. Aug 30, 2019 at 5:37 PM
    #167
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :popcorn:
    Looking forward to exciting updates
  8. Oct 10, 2019 at 9:59 AM
    #168
    MikieSwartz
    Carlisle PA
    Sorry for the extreme slacking. I've been so busy with other things, plus I was at a turning point in the build so I put it on hold until I could make the best decision. That decision has been made and I finally have a news-worthy video to share! Please comment on the video on YouTube - it helps the channel + I'll see it there and respond. Thanks for all the support TacomaWorld! And no, I'm not actually doing a body lift! LOL
    https://youtu.be/Tpj648trk6s
  9. Oct 11, 2019 at 5:53 AM
    #169
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Sweet!
    Keep it going Mike!
    MikieSwartz[OP] likes this.
  10. Oct 11, 2019 at 8:32 AM
    #170
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Someone one YouTube mentioned cutting the frame before the rear cab mount. Then adding in a section of frame 4" long. That is probably the best idea I saw in the comments section.
    Keeps all of the bolt locations for the bed in the same location, as well as makes the rear cab mount easier to deal with for relocation. Since it is on a slope of the frame. Then you only need to move the front mounts. Way easier overall, to meet your goals, in at least our two opinions.
    Bobby18 and MikieSwartz[OP] like this.
  11. Oct 11, 2019 at 8:33 AM
    #171
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Keep up the work. Glad to see your new video, as I was hoping you were still focused on it. :thumbsup:
  12. Oct 11, 2019 at 11:18 AM
    #172
    MikieSwartz
    Carlisle PA
    Thanks for the advice! I'm definitely going to consider that.
    Torspd[QUOTED] likes this.
  13. Oct 11, 2019 at 11:19 AM
    #173
    MikieSwartz
    Carlisle PA
    I don't focus very well. LOL But I'm really excited to have this cab lifted up off the frame. Its making all of this work so much easier.
    3 Blade Rage and Torspd[QUOTED] like this.
  14. Oct 11, 2019 at 11:33 AM
    #174
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LOL. It all comes back around though. Now let's see some more :sawzall: and :welder::cheers:
  15. Oct 11, 2019 at 11:35 AM
    #175
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cause I want to see some :burnrubber::mudding:
    MikieSwartz[OP] and nd4spdbh like this.
  16. Oct 11, 2019 at 5:43 PM
    #176
    3 Blade Rage
    3 Blade Rage Active Member
    Central Pa
    2010 Brown Mica Tacoma Sr5
    I want to see some more of the chick dancing!
    MikieSwartz[OP] and Lord Helmet like this.
  17. Oct 12, 2019 at 4:56 PM
    #177
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Maybe he can get one to wrench on the truck!
  18. Oct 14, 2019 at 2:22 AM
    #178
    3 Blade Rage
    Central Pa
    Heck ya! He better do it quick though it is starting to get Nippy around these parts.
  19. Oct 29, 2019 at 1:31 PM
    #179
    MikieSwartz
    Carlisle PA
    I've got a special Halloween episode for you guys. And I should probably announce that I've decided to really put a lot of time and effort into some key elements at this point:
    1. I'm sliding the entire cab back 4" on the frame so the engine and trans can also slide back and get better weight distribution to the back wheels.
    2. I'm focusing on keeping the lowest center of gravity possible - sinking the engine in as deep as possible and refusing to lift the cab at all for clearance.
    3. I'm trying to keep everything (mainly the transfer case) above the bottom of the frame rails for maximum clearance.
    I must admit, this has gone from just an engine swap to a full-on build. I'll also be mounting the 10.5" GM axle and trailing arm suspension while the cab is off. I might even just tube the rear while I'm at it. I'm going to keep it within the rules of an Ultra4 4500 class truck just in case. ;)
    https://youtu.be/0frM7sos34k
    slvrtaco11, Speedo, Torspd and 15 others like this.
  20. Oct 29, 2019 at 3:03 PM
    #180
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
