Tag lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05TacomaGirl, Dec 1, 2023.
  1. Dec 1, 2023 at 8:01 AM
    05TacomaGirl
    05TacomaGirl [OP] Well-Known Member
    Tampa, FL
    2005 Toyota Tacoma prerunner V6 SR5
    I need some help, I have a 2005 prerunner and 1 of my tag lights works when it wants to. I have changed the bulb 4 or 5 times and have even gotten a new wiring harness. But it still works when it wants to.
  2. Dec 1, 2023 at 8:27 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    You using Led or oem bulbs? Cheapo led bulbs work when they want to.
    Island Cruiser likes this.
  3. Dec 1, 2023 at 12:12 PM
    05TacomaGirl
    Tampa, FL
    LED but they won't cheap.
  4. Dec 3, 2023 at 8:18 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
  5. Dec 3, 2023 at 10:07 PM
    05TacomaGirl
    Tampa, FL
    I have those, I have upgraded every light on my truck. But the left tag light still works when it wants to. I can take my fist and beat on it. And then will come on for a few seconds and then pop right back off. And sometimes that doesn't even work. Everything about it is New, the right one works great. But the left does whatever it wants to do.
  6. Dec 3, 2023 at 10:25 PM
    EL DUDE
    EL DUDE Well-Known Member
    It may be bad. Or the company you’re getting it from suck.
    I’ve replaced the interior replacement LEDs in my wife’s van 3 times. They failed everytime. Each batch they sent, the lights would fail after a day, or week. And flicker, or not be on.
    Buy good stuff and be done
  7. Dec 4, 2023 at 5:08 AM
    05TacomaGirl
    Tampa, FL
    If that was the case, my dome lights wouldn't work, my map lights wouldn't work and the right tag light wouldn't work. Everything works but the left tag light, so it's not the company or the LED lights they sale. There has to be something wrong with the left tag light wires or something.
    TOMB likes this.
  8. Dec 4, 2023 at 5:23 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Do a sanity check and swap in a regular halogen bulb to see if the issue remains.
  9. Dec 4, 2023 at 5:58 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Sounds like a short somewhere if you can beat on it and the light will come on briefly.
  10. Feb 29, 2024 at 11:13 AM
    cardigan
    cardigan Member
    2009 Tacoma DCLB TRD Sport
    Did you check the wires past the plug? I had similar issues and it ended up being a wire rubbing against metal and it was shorting. I soldered it back up, taped it and haven't had issues since. Also make sure you're putting dielectric grease in the plug before connecting your new lights. Corrosion will make it act funny.
    Rob MacRuger likes this.
  11. Feb 29, 2024 at 11:16 AM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    Do they make these for 2022? these look awesome.
    TOMB[QUOTED] likes this.
