Tail and Dash Lights- not a fuse?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tac0_2sday, Dec 27, 2018.
  1. Jan 12, 2019 at 6:39 PM
    Tac0_2sday
    Tac0_2sday [OP] Active Member
    Eric
    ‘23 Tacoma TRD OR 4x4
    So I finally took it to a mechanic, and I just got the call today that the the entire relay box needs to be replaced.
    The guy said I have two options:
    1) some type of bypass method that would fix the issue at hand ($200)
    2) replace the relay box entirely and fix it right ($800+)
    He was very confusing over the phone, so will have to wait until they open again to better understand my choices.
  2. Jan 13, 2019 at 2:58 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    By relay box just what do you mean ??
    This is then brand new for $800.00 and installed?
    Integration relay or some call it the body ECU .
  3. Aug 13, 2022 at 3:07 PM
    901/662 Taco
    901/662 Taco New Member
    Brandon
    Green 2001 Tacoma
    I’m having this issue now. What was the issue?
  4. Aug 13, 2022 at 10:36 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It seems the OP never came back and told how the issue was resolved.
    Just what is your problem Brandon?? No tail lights? Did the usual Checked the fuse?
  5. Aug 14, 2022 at 8:53 AM
    901/662 Taco
    Brandon
    Green 2001 Tacoma
    I checked the fuse and it was blown so I replaced it and everything was back to normal. I recently installed a trailer wiring harness and have pulled the trailer several times with no issues. Friday night I hooked the trailer up for Saturday morning and when I left the house I noticed my instrument cluster lights weren’t working nor were my tail lights on truck and trailer. Brake lights and turn signals worked fine though. I also checked fuse for the cluster lights and that fuse was fine. But like I previously mentioned, the dash lights and tail lights are working now after replacing fuse. Not sure why the fuse blew unless it was coincidentally that time.
    GirlMud01Taco4x4 likes this.
  6. Aug 14, 2022 at 9:04 AM
    Bivouac
    Head lights work fine?
    Double check the fuse . Fuse loose in the socket?
    Since the lights on both are not working if it was a open circuit in the trailer harness the truck lights should still work.
    loose connection in the tail light circuit drawing to much current opens the fuse.
    brake lights and turn signals are separate circuits to the converter box then they all get merged.
    Converter boxes seem to cause no end of light problems.
    Good luck!
