Tail Gate question
Discussion in 'Technical Chat' started by rob99vmi04, Sep 17, 2008.
  1. Sep 17, 2008 at 8:00 AM
    rob99vmi04
    rob99vmi04 [OP] Member
    Fairfax
    SR5
    Again, I apoligize for the ignorance already printed the TSB on the Bed...
    From what you said on the suspension the remaining TSB's I need to print is SV002 SV006... and insist on the alignment report.
    and TC004 for the squeaky Clutch?
  2. Sep 17, 2008 at 8:03 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I don't know the numbers.
  3. Sep 17, 2008 at 8:10 AM
    rob99vmi04
    Fairfax
    SR5
    A TSB is not a recall.
    AU001-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
    AU001-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
    BO001-06 JAN 06 Body - Front/Rear Window Runs Deformed
    BO003-05 MAR 05 Body - Overfender Refinishing Process
    BO004-05 APR 05 Body - Water Leaks Onto Front Floor
    BO018-07 NOV 07 Body - Bent Rear Tailgate
    BO022-06 NOV 06 Interior - Driver's Side Lower Dash Panel Poor Fit
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
    EG021-06 APR 06 Exhaust System - Ticking Noise Between 2,000-2,500 RPM
    EG043-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
    EG046-06 AUG 06 Intake System - Air Intake Hose Rattle
    NV003-06 MAR 06 Body - Front End Rattle/Squeak on Bumps
    NV004-06 MAY 06 Interior - Front Seat Squeak Noise
    NV006-07 AUG 07 Body - Windshield Wind Noise at Highway Speeds
    NV007-05 JUN 05 Body - Front/Rear Popping/Knocking Noise on Rough Roads
    NV007-07 JUL 07 Body - Dech Side Panel Rattle
    PD039-04 SEP 04 Pre Delivery - Initial Calibration Of Compass
    PD075-06 AUG 06 Pre Delivery - TPS Initialization Procedure
    PG004-06 NOV 06 General - TPS Diagnostic Tips
    SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
    SU002-05 NOV 05 Suspension - Rear Suspension Noise
    SU006-07 SEP 07 Suspension - Harsh Rear Spring Ride With Heavy Loads
    TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
  4. Sep 17, 2008 at 8:13 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I probably wouldn't bother with the SU002-05.
    You should also bring in the BO018-07
  5. Sep 26, 2008 at 6:10 AM
    rob99vmi04
    Fairfax
    SR5
    UPDATE*** Got my truck back today!!
    Brand NEW Tailgate WHOOOO HOOOOO
    Brand NEW SUSPENSION -It says Front and REAR WHOOOOO HOOOOOO
    CLUTH Peddle Doesn't make that stupid squeak anymore.
    It actually feels like a differn't more solid truck now.
    THANKS TO EVERYBODY!!!!!!!!!!!!
