Tail gate theaf!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dave2017Taco, Dec 30, 2017.
  1. Dec 31, 2017 at 8:39 AM
    #81
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Thought this stopped working after about a year...
    T4RFTMFW likes this.
  2. Dec 31, 2017 at 8:40 AM
    #82
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Does. The “redesigned” version works slightly longer. :D
    tcjacado likes this.
  3. Dec 31, 2017 at 8:41 AM
    #83
    GreekPEguy
    GreekPEguy Well-Known Member
    California
    2002 Prerunner, 3.4 TRD OR
    I had a co worker who's tailgate was stolen recently. He went to home depot and was only in there for 10 min. and it was gone. Dealer wanted about $2000 to replace it. (It's a 2015 Tacoma). This was also in central California, it seems thefts come in waves, because I'm noticing missing tailgates on all types of trucks while driving around town.
  4. Dec 31, 2017 at 8:45 AM
    #84
    venezian
    Los Angeles
    2022 7545E
    $109 for a year and slightly longer vs. $5 for a hose clamp.
  5. Dec 31, 2017 at 8:59 AM
    #85
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I feel your pain, mine got stolen a couple of years ago. Now I have a locking handle, hinge clamp, and tailgate cable washer mod. ;)
    over60 likes this.
  6. Dec 31, 2017 at 9:23 AM
    #86
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    I like it because I'm picturing some jackass taking the time to unscrew the hose clamp and going "aw hell!" when they hit the zips.
    cshrum and JGO like this.
  7. Dec 31, 2017 at 9:26 AM
    #87
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    I tried the hose clamp mod but the clamp kept slipping off the hinge. Couldn't get it to work.
    airborndad likes this.
  8. Dec 31, 2017 at 10:11 AM
    #88
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Exactly. I wrapped 2 of them side by side tightly. It won’t stop someone who’s dedicated, but should slow them down a bit more. Every second counts.
  9. Dec 31, 2017 at 10:17 AM
    #89
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    How many of you have ever removed their tailgate for whatever reason? I was talking with a neighbor about this yesterday, and he showed me his hinge on his work pickup- he welded a small piece of pipe bend over the slot on the hinge, permanently locking it on the truck. He said if he ever wanted to take it off, he could use “this”, holding up his hand held lithium battery powered mini grinder. He also offered to weld mine if I wanted to. Any reason not to? Seems the only purpose to take off the tailgate would be to repair it or something. Is it possible to open up the cover and remove the hinge pin from the inside if I ever want to take the tailgate off the truck?
  10. Dec 31, 2017 at 10:27 AM
    #90
    Taco16LB
    Taco16LB Well-Known Member
    I used to have to remove the tail gait on my chevy's when using a cab over camper . It was sometimes easier to sweep out the box after unloading gravel or dirt also. My Tacoma is more of a small fishing boat hauler than a heavy hauler though , so I see no need to remove it but I would not want it welded .
  11. Dec 31, 2017 at 10:31 AM
    #91
    OnHartung'sRoad
    I didn’t think about the cabover - now I remember that some utility and expedition caps also have custom gates, too. you are right about gravel - that’s hard to clean out of the space between the tailgate and the bed! Hey, sounds like you were treating your Chevy like a real truck!
    So, if the hinge pin can be taken off the tailgate by opening the cover, it can be pulled out of the pin mount on the bedside. I’ll have to see if that could work, because I’d only consider the weld if I could still take the gate off some way without cutting the hinge. Thanks for your input!
    Taco16LB[QUOTED] likes this.
  12. Dec 31, 2017 at 10:49 AM
    #92
    OnHartung'sRoad
    I also noticed that the 2 cable ends designed to slide off may be kept from sliding out to deter a thief (unless he cuts the cables or has the right torx socket wrench) by unscrewing the torx bolt holding the cable mount on the bedside and placing a large washer over the cable eye before screwing the bolt back down.
    over60 likes this.
  13. Dec 31, 2017 at 10:53 AM
    #93
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    I had to replace a tailgate once. Went on Craigslist and couldn't believe how many were for sale. Bought one off a work truck who's work camper shell took place of it, but I knew it wasn't stolen so I was happy about it. He wanted more then most craigslist ads but he agreed to price match. Also had a relatives tacoma tailgate stolen. First mod I bought for my new Taco was a Sabellco tailgate lock, they have a Christmas sale on right now. If they still manage to steal it, I'm not sure if he only exists in the comics or not, but I'm calling The Punisher.
    EDDO and Kamzilla like this.
  14. Dec 31, 2017 at 11:03 AM
    #94
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Pop n lock. 2 years still works fine!
  15. Dec 31, 2017 at 11:36 AM
    #95
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    Every time something tailgate related comes up and theft I always think about this thread something about it is always just fishy, "my friend replaced his tailgate with a carbon fiber one" i asked him about because i never seen a carbon fiber tailgate unless someone can post a picture of one lol.
    https://www.tacomaworld.com/threads/gone.522943/#post-16621556
  16. Dec 31, 2017 at 11:53 AM
    #96
    OnHartung'sRoad
    Woah, surprised that thread isn’t locked with a warning- not a accusation, just a warning for sellers to provide source documentation to help deter sales of black market parts.
  17. Dec 31, 2017 at 11:55 AM
    #97
    SLO TRD
    SLO TRD Living the SLO life.
    Gene
    San Luis Obispo, Ca.
    2016 Magnetic Grey TRD Sport DCLB
    Snugtop, 5100's, weather tech mats floors, truck bed, Tinted front windows.
    Wat in tarnation...
  18. Dec 31, 2017 at 11:58 AM
    #98
    crisanalex
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    Yeah, i thought it was because he never replied to me. I'm not one to accuse off of suspicions, everyone's shit stinks but the this one smells a little more lol.
  19. Dec 31, 2017 at 12:02 PM
    #99
    OnHartung'sRoad
    Usually, people replace their tailgates with those “carbon fiber” (net ones?) after they’ve been victimized, never heard of someone doing that to replace a regular tailgate.
    Also, doing anything “for a friend” is like the number 1 red flag a parent hears from their kids - “that’s not my (insert whatever here), I was keeping it for a friend”.
  20. Dec 31, 2017 at 12:05 PM
    #100
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Really don't get why or how their is a huge market for these tailgates... You would only need one IF.
    1) Tailgate was stolen
    2) Damaged, like someone backed into you or you backed into something.
    They don't fit second gens without modification.
    If I was a thief, I would take a tailgate, find another truck of the same color, hammer his tailgate and post my shinny new one on CL. That's the only way I could see it worth taking...
