Tail light assembly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Twist18, Jan 26, 2024.
  1. Jan 26, 2024 at 5:17 PM
    Twist18
    Twist18 [OP] Member
    Patrick
    2022 White Tacoma SR5
    My son backed my truck into a tree today. Luckily the only damage is a broken taillight housing. Where is the best (cheapest) place to get a new assembly? I was thinking eBay or Amazon, but I want to make sure I get genuine Toyota parts.
  2. Jan 26, 2024 at 6:22 PM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    Genuine ones are under $150. Less if you only need the lenses. There's a ton of OEM parts dealers online I would go to them before Amazon or ebay. If you want to save a few dollars you can call around junk yards.
    Chew likes this.
  3. Jan 26, 2024 at 6:26 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  4. Jan 26, 2024 at 6:29 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Facebook Marketplace. You can get OEM lights, which are far superior to ALL aftermarket lights, for under $100.
    Ideally, aim for the 2019 red tails. They have a red lens, but the internal plastics (side of the turn signal bucket) are black. Easily the best looking OEM tails.
    If you don't have FB Marketplace or don't know how to use it, make the kid find them for you... he caused this mess.
    On a positive note, he broke the cheapest and easiest to replace body part.
    musicisevil likes this.
  5. Jan 26, 2024 at 8:12 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I don't believe the lenses come loose from the housings. The OP will probably wish to match the right and left, so he is stuck with the Toyota units.
    Chew likes this.
  6. Jan 26, 2024 at 8:25 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    BAM Wholesale Parts.
