tail light blinker issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by mike sacc, Mar 3, 2011.
  1. Mar 3, 2011 at 1:52 PM
    mike sacc
    mike sacc [OP] Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    i have an 01 tail light left blinker problem. when the left blinker is on the runners come on and the rears blink. if i put the runners on everything works properly. pulled runner fuse put test light in there and it was blinking on the ground side. even with no runner fuse, if i turn on the blinkers on the rear runners blink. any info would be helpfull. thanks.
  2. Mar 3, 2011 at 1:55 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Probably a ground problem or a short to the blinkers/runners. Check all the light connections for corrosion and shorts.
  3. Mar 5, 2011 at 1:36 PM
    mike sacc
    r.i.
    checked everything out today it all looks good. do you think it might be the combination light / blinker switch
  4. Mar 6, 2011 at 9:38 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    It's a good suspect, but parts changing as a diagnostic tool gets expensive fast. Electrical parts are usually non-returnable.
  5. Mar 6, 2011 at 3:23 PM
    mike sacc
    r.i.
    parts train $42, got to try somethin inspection sticker is up at the end of the month.
  6. Mar 6, 2011 at 8:27 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Do you have trailer wiring? I had a converter box fry and started doing crazy stuff to my lights.
  7. Mar 7, 2011 at 2:50 AM
    mike sacc
    r.i.
    yes i do. didnt want to mess with it . it looks factory and looks like it is still sealed , if that makes a difference.
  8. Mar 7, 2011 at 3:16 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Did you try adding some
    I have no good input though, hope you figure it out man.
  9. Mar 7, 2011 at 3:24 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I knew I would see this!
    Beau FTW
    But seriously you will probably need a wiring diagram and start to eliminate different parts in the circuit.
    Scroll down for 2001 Tacoma.
    http://www.ncttora.com/fsm/
  10. Mar 7, 2011 at 3:36 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    :thumbsup: Thats what im here for
  11. Oct 24, 2011 at 12:35 PM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    I'm having a very similar issue. I have an 01. When the headlights are turned on, and I use the blinkers, all rear lights including my brake lights, indicators, and third brake light. The front blinkers work okay. While they do this, the relay clicks very fast like a bulb is out, but nothing is out. When I press the brake while the headlights are on, they work fine.
    Now, when the headlights are off, everything works fine until I press the brake, the I have the same problem as mentioned before. Let me know if you get this solved, because I have no idea how to fix this.
    Oh ya, the guy before me had HIDs, I had an issue with these, but i am not sure if they would have affected my brake lights. I had an issue switching back and forth between hi and low. When I would, only one side would work. I took the, the, apart and reinstalled them, now neither work lol.
  12. Oct 26, 2011 at 3:49 AM
    mike sacc
    r.i.
    had similar problem.new trailer light harness did the trick.30 bucks
  13. Mar 3, 2012 at 1:47 PM
    pikuptruk
    Vallejo
    01 4x4 2.7 Lifted
    If you look back at my post, I had an issue with my blinkers. Sometimes they were blinking rapidly(no the light was not burnt out), however a similar issue was the culperate. The guy who owned the truck before me had tried to do a light mod, looks like he failed and went back to stock. When he did this, he got sloppy with sticking one of the taillight wares back into the female end, right on the actual tail light harness. A couple of the wires frayed, bent out and over the slot where the wire is inserted. It was grounding out.
    My purpose for posting this is to explain the importantce of searching for a short. Take apart your lights, every light and check the connections. I even had a professional electrician trouble shoot this, and he never bothered to check the obvious. He thought it was something more critical. Feel free to message me if you need any advice with this. I spent some time being quite frustrated, and I'll be glad to save you the frustration....
