Tail light conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dajeepman, Sep 2, 2017.
  1. Sep 2, 2017 at 8:54 PM
    Dajeepman
    Dajeepman [OP] Well-Known Member
    Andrew
    Pittsburg , Tx
    2006 Gold Tacoma base 4x4
    I ripped my pass side tail light off. I found a set of TRD led tail lights off a 14 taco. Will they hook up on my 05?
  2. Sep 2, 2017 at 9:05 PM
    Pigpen
    Dan
    Northwest Montana
    Yep. Direct fit.
    /thread
    BassAckwards and Key-Rei like this.
  3. Sep 2, 2017 at 10:29 PM
    Dajeepman
    Andrew
    Pittsburg , Tx
    Thanks
  4. Sep 3, 2017 at 5:35 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    How did you rip your tail light off?
  5. Sep 3, 2017 at 6:04 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    All the tail lights are the same. There are no TRD tail lights. 05-08 had the non led tails. 09-15 had led tails.
    Tacoma HEART likes this.
  6. Sep 3, 2017 at 6:07 AM
    Dajeepman
    Andrew
    Pittsburg , Tx
    At Gilmer wheeling at Barnwell Mt. Came off a ledge and landed on the bumper end and it pushed up and popped my tail light out. And broke the tabs on the taillight housing
  7. Sep 3, 2017 at 6:08 AM
    Dajeepman
    Andrew
    Pittsburg , Tx
    Here some of the trails we was on.
  8. Sep 3, 2017 at 7:37 AM
    Pigpen
    Dan
    Northwest Montana
    Fuck yeah
  9. Sep 3, 2017 at 9:08 AM
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    2021 Tacoma DCLB SR
    Will going from a none LED to LED affect the electrical system?
  10. Sep 3, 2017 at 10:21 AM
    moondeath
    Pa, Gardners
    Only if you're using non oem leds. The oem led tail lights will work fine. If you use non oem leds in turn signals you will need resistors to prevent the turn signals from hyper flashing.
    Crooked Beat[QUOTED] likes this.
  11. Sep 4, 2017 at 6:51 AM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Thank you.
  12. Jan 21, 2020 at 5:23 PM
    Ginger-Vitis
    Ginger-Vitis Well-Known Member
    08 Tacoma 5spd
    Do I need a different wiring harness if I'm putting LEDs in my 08 Tacoma?
  13. Jan 21, 2020 at 5:29 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Nope
