Tail light dash light fuse problem solved!
Discussion in '1st Gen. Tacomas (1995-2004)' started by revwilliec, Jun 5, 2014.
  1. Jun 5, 2014 at 7:40 PM
    revwilliec
    revwilliec [OP] New Member
    Willie
    Fayetteville NC
    01 Prerunner
    I have a 2001 Double cab Tacoma. The other day I notice no dash light?!! Some guy pulls along side hollers "hey buddy, you got no tail lights." I locate the 10 A fuse under the hood for the dash/tail lights. It is blown. Replace it and turn on the light, blows again. I went to parts store and was told to disconnect the tail lights turn on lights. If fuse blows problem is in the dash, if not problem is in the tail lights. Disconnected tail lights and fuse did not blow. Problem is in the tail! I went to Tacoma world and find some talk about checking the tail light bubs for corrosion, the trailer connector wiring then someone mention the trailer harness behind the driver's side tail light! Found it is known to corrode and cause short. I notice the markings to truck and to trailer. Notices wiring for each light. Only one needed to be cut. I cut the tail light wire between the truck and the harness. Problem solve. Only need to replace harness box if I pull a trailer which needs tail lights.
  2. Sep 18, 2014 at 5:44 AM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    Thats great. I have same truck same problem. I thought it had something to do with some light mods I did. This will be a big help
  3. Nov 9, 2024 at 11:22 AM
    02TacomaBeater
    02TacomaBeater New Member
    This mega-old thread just saved me so much hassle. If you're still out there somewhere, thank you!
    ControlCar and Madjik_Man like this.
