Tail light not working
Discussion in 'Lighting' started by Neef, Mar 20, 2014.
  1. Mar 20, 2014 at 10:58 AM
    Neef
    Neef [OP] Member
    Canada, BC
    2008 Tacoma trd sport
    Hey guys,
    I have a 2008 DCLB that i bought in December that has a tail light issue. The tail light doesnt work but the brake light does.
    It has a factory trailer wire harness that looks to be installed professionally. I havent tested any wires at the tail lights yet or closer to the cab(I dont have a voltmeter...yet). I have searched the forums but didnt come up with a whole lot other than aftermarket trailer wiring harness causing the problem and the wires ontop of the fuel tank rubbing.
    Is it possible to just jump off of the other tail light wires or do I need to jump over the dammaged wire that is running to the problem tail light?
    Wondering if anyone else has had this problem and what their solution was.
    Thanks
  2. Mar 20, 2014 at 11:09 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Did you try a new bulb? Checked the fuses?
  3. Mar 20, 2014 at 11:11 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    its a fuse....does it shift out of park? if not its the 10a fuse.
  4. Mar 20, 2014 at 12:19 PM
    Neef
    Neef [OP] Member
    Canada, BC
    Bulb and fuse were the first things I check.
    Yes it shifts out of park:) I didnt know that if you blew a tail light fuse it doesnt shift out of park!?! wow
    Thanks for the input
  5. Mar 20, 2014 at 2:57 PM
    L J
    Illinois
    I would think if it shorted out due to a wire rubbing the fuse would blow. Is the socket that the taillight plugs into corroded? If it has aftermarket trailer wiring that would be the most likely place to look.
