Tail Light & Parking Light Issues (2002 Tacoma)
Discussion in 'Lighting' started by NavChief, May 19, 2016.
  1. May 19, 2016 at 7:56 AM
    NavChief
    NavChief [OP] New Member
    Oakland,Ar.
    02 Tacoma Limited
    HP intake, 4" lift
    Tail lights & Front Side Lights went out. Checked every fuse in the truck, in the cab and under the hood. They were all good. Front left side bulb and connector are corroded, will clean or replace. Pulled the lens cover off the rear tails. The backup light twists into the cover but the turn & and tail light bulbs have a metal connector that I would like to know how it is removed before I start cranking on it. Does it twist or just pull out? Any help or advice would be greatly appreciated!
