Tail light problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rschap, Sep 21, 2016.
  1. Sep 21, 2016 at 8:02 PM
    Rschap
    Rschap [OP] Active Member
    Randall
    Grand Junction
    98 4X4 Limited
    I noticed I had a break light out so I bought a new bulb and replaced it. While replacing it I put the grease on the bulb connector and still had quite a bit left in the little tear off package so I pulled the other bulbs in the housing and greased them as well. It appears that the previous owner didn't believe in bulb grease so the turn signal bulb was corroded to the back piece and it pulled out with the bulb. I put it back together and it now works intermittently. Can I replace just the socket for the turn signal or do i need to replace the whole housing? Where can these parts be found? Thanks for any help.
  2. Sep 24, 2016 at 9:14 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I read your post and don't have any ideas other than to go to a junk yard and get a replacement for the entire assembly. Make sure you check the condition of all the sockets beforehand. Perhaps somebody else could help out - I can't believe you are the only one with this problem. Good luck!
  3. Sep 25, 2016 at 9:19 AM
    col. sandurz
    col. sandurz Well-Known Member
  4. Sep 25, 2016 at 12:35 PM
    Cosman
    Cosman Well-Known Member
    San Diego, CA
    2000 Tacoma Single Cab 2.7 4x4 Manual EVERYTHING
    Check the backside where the ground attaches to the housing. I had an intermittent brake light issue and it turned out the ground wasn't making great contact.
    If you wanted a new connector, I know Dorman makes replacement pigtails for light sockets. Oreillys and Autozone should have them.
