Tail Light Stuck On
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buff Kiwi, Sep 20, 2019.
  1. Sep 20, 2019 at 1:46 PM
    Buff Kiwi
    Buff Kiwi [OP] New Member
    2001 4 cyl SR5 Manual Xtracab
    My left tail light is stuck on for some reason. I noticed on some late night driving where the left looked bright like I was braking but the right looked normal. Any ideas? The right seems to function fine. I replaced the brake tail light just a little bit ago.
  2. Sep 20, 2019 at 2:09 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Got an aftermarket
    Brake trailer light controller? They’ll do weird things when they go bad
  3. Sep 20, 2019 at 7:04 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The dual filament bulbs can only be installed one way, but sometimes it's possible to force it in 180° off. If you did that the brighter filament (brake light) would be on when dimmer taillight should be on.
    Other than that these problems are usually related to loose or corroded wires/grounds. Trailer connector are notorious for corroding and causing problems.
    Another thing to check is the contacts at the bottom of the bulb sockets. They can melt and cause shorts between the terminals.
    Wyoming09 likes this.
