Tail light trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtlogger, Oct 17, 2017.
  1. Oct 17, 2017 at 4:44 AM
    vtlogger
    vtlogger [OP] Well-Known Member
    jerry
    bridport
    tacoma
    small 2" lift 32" tires
    So got this trouble with my left side tail light.. when I step on the brake the left turn signal indicator in the dash lights up.. not bright but you can see it. If I step on the brake when using the left turn signal it flashS fast, let off the brake it goes back to normal .. all the lights work.. any ideas where I should start looking for the trouble??
  2. Oct 17, 2017 at 5:09 AM
    fenmik
    fenmik Well-Known Member
    Nova Scotia, Canada
    2019 Double Cab TRD Sport.
    Do you have a trailer wiring harness on your truck? If so it could be that causing the problem. If not then sounds like a bad ground to me.
  3. Oct 17, 2017 at 6:04 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Oct 17, 2017 at 6:09 AM
    vtlogger
    jerry
    bridport
    tacoma
    Yes it has trailer wiring, but have unplugged it thinking that was what was causing it. Still doing it after
    Dalandser likes this.
  5. Oct 17, 2017 at 6:12 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I had this issue, eneded up being moisture in my fuse box inside the cab. It was also causing my reverse lights to illuminate dimmly.
  6. Oct 17, 2017 at 9:05 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Have you replaced any bulbs recently? Check bulbs for good connection. When you unplugged trailer harness did all the connections look clean and none were burnt? It sounds like a ground problem. Use a volt meter and check ground continuity from light socket to frame.
    Not a good place to have moisture.
  7. Oct 17, 2017 at 9:32 AM
    Key-Rei
    Key
    Florida
    No it's no. :rofl:
    It was getting water in the box from a bad sun roof drain, all sunroof's are a controlled leak, and it's only a matter of time before it's uncontrolled.
    It was that experience why I will never own another vehicle with a sunroof. :anonymous:
    mechanicjon[QUOTED] likes this.
  8. Oct 17, 2017 at 9:49 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Sounds like a short to power or a short to ground. One of the wires responsible for the brake light might be rubbing against the wire for the turn signal. Hell one of the copper traces on the instrument cluster might be arched.
    I'd say check for damage to any wiring but it could be something else.
  9. Oct 17, 2017 at 10:07 AM
    Glamisman
    Glamisman Well-Known Member
    see if this helps
  10. Oct 17, 2017 at 5:18 PM
    vtlogger
    jerry
    bridport
    tacoma
    Thanks for all the help.. I'll dig it to tomorrow and see what I can find..
    Plugs looked good.. trailer hitch and wiring are only 2 month old
