Tail light wiring help help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dumas1052, Mar 19, 2013.
  1. Mar 19, 2013 at 8:32 PM
    Dumas1052
    Dumas1052 [OP] Member
    Bryan
    Arizona
    Long travel 95 taco
    Long travel, fiberglass body,
    I bought new tail lights for my prerunner. Cause someone cut them out of my truck. I called Avondale Toyota in Arizona. And they told me that there was no connector off the wiring harness:confused:. But my new lights came with a six pin connector? Does anyone know what the part number is or can direct me in the right direction?
  2. Mar 19, 2013 at 9:01 PM
    joeer77
    joeer77 Active Member
    North Plains OR
    Bilstein 5100s
    So you need the female connector from the wiring harness? Try this website: http://www.villagetoyotaparts.com/ and you can look up Toyota parts by year. I found PN 90980-10173 for 1995 Tacoma 2.4L manual tranny. $7.88.
  3. Mar 19, 2013 at 9:03 PM
    Dumas1052
    Bryan
    Arizona
    Long travel 95 taco
    That is exactly what I need coming off the harness, thanks
  4. Mar 20, 2013 at 8:13 PM
    Dumas1052
    Bryan
    Arizona
    Long travel 95 taco
    Buy any chance do you know the part number for the wires and go inside than connect, I called the dealer today and they want 8 bucks for each wire, and I need 10 I'm really tring not to spend 80 bucks for 10 wires. So I can try to look online for them
    Thanks
  5. Mar 20, 2013 at 8:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I would either go down to the junkyard and cut the connector needed off a wrecked truck, or go to NAPA and buy a couple of trailer light plugs. Looks like you have only five wires in that plug? They make a 5 pin "flat" trailer connector. Buy a couple of those and a handful of splice connectors. Tape up the splices real well and call it good. It will be a heck of a lot less than 80 bucks.
  6. Mar 20, 2013 at 8:30 PM
    joeer77
    North Plains OR
    Bilstein 5100s
    The dealership can give you the Toyota part numbers over the phone even if you don't buy it there. You should be able to crimp new female spades on your existing wiring and put them in the new connector. Not sure why you need new wiring.
  7. Mar 20, 2013 at 8:40 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Bring the tail light with you to radio shack and just buy the blade connectors if the wire still reaches. Then once connected fill the voids with hot glue gun. "Budget" best would be the junkyard
