Tail lights, brights not working
Discussion in 'Technical Chat' started by chonko, Feb 11, 2011.
  1. Feb 11, 2011 at 5:46 AM
    chonko
    chonko [OP] New Member
    Joe
    Virginia
    I recently installed an after-market CD player into my 07 Taco and since then my climate control backlights, tail lights and high-beams are not working. Brake lights and low-beams operate fine. I checked fuses briefly last night when I realized all these lights suddenly stopped working and didn't see anything that was blown. I will check again this evening. Any ideas of what this could be outside of a blown fuse?
  2. Feb 11, 2011 at 6:34 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Some aftermarket radios have a wire marked "Dimmer" or something similar. I've seen instances where people have wired that into their back lighting circuit for the factory radio and it has caused similar issues. Might check that.
  3. Feb 11, 2011 at 7:49 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Check your TAIL fuse. Your dash illumination is powered off the taillight circuit.
    My guess is that the new head unit's illumination / dimmer wiring connection is the root cause.
  4. Feb 11, 2011 at 8:10 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Probably the dimmer wire.
    I never connect the dimmer wire when I install headunits.
