Tail Lights not coming on with DTRL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skipperducker, Mar 23, 2015.
  1. Mar 23, 2015 at 6:17 PM
    skipperducker
    skipperducker [OP] Active Member
    Nova Scotia
    2007 TRD Yamaha Edition
    aluminum rack, 2" leveling kit, soon to be lights and tires
    You see, I find it weird how the lights cause no problems when using brake lights, however I turn on my headlights they blow the fuse. Headlights I have removed from the equation by taking out the fuses, so It's the tails somewhere.
  2. Mar 23, 2015 at 6:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I wouldn't have even touched the headlights since they are not the ones causing you issues and are still on. That would be one of the last circuits I would touch if I was at wits end with the problem. Have you taken out the tail lights entirely yet and installed a fuse as I previously suggested?
    When did this problem begin anyways?
  3. Mar 23, 2015 at 6:24 PM
    skipperducker
    Nova Scotia
    Just putting the old tails back in, to see if they will work. Will let you know
  4. Mar 23, 2015 at 6:32 PM
    skipperducker
    Nova Scotia
    Just popped it with old lights in, wire tracing time now eh? Or what else could it be
  5. Mar 23, 2015 at 6:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Turn signal stalk possibly. It's the only other circuit within the wiring which controls the headlights and tail lights.
    Again, when did this start happening?
  6. Mar 23, 2015 at 6:38 PM
    skipperducker
    Nova Scotia
    After I put my new tails in today about 3 hours ago. Just noticed it when My buddy said I had no tail lights driving in the dark. Its fine with break lights, reverse lights and blinkers. But as soon as I turn on my lights, (head and tail) fuse gets blown
  7. Mar 23, 2015 at 6:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You probably pinched the red an green wire at the wiring harness leading up to the tail lights during install of the new ones. Check that area carefully.
  8. Mar 23, 2015 at 7:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Excuse me, I mean you probably pinched the solid green wire.
  9. Mar 23, 2015 at 7:00 PM
    skipperducker
    Nova Scotia
    I'll take it that that green wire with the red stripe is the wire for the tails from the light switch correct? I checked it over and didn't see any issues
  10. Mar 23, 2015 at 7:15 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You don't magically get issues after simply swapping out tail lights. Check your harness over good. The solid green is running lights for tail lights on lights mode, the green with red stripe is when you press the brakes.
  11. Mar 23, 2015 at 7:24 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
  12. Mar 23, 2015 at 8:00 PM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Mechanical and electrical problems are usually caused by the last operation performed before the problem surfaces. You were messing with the wiring.
  13. Mar 23, 2015 at 8:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Exactly.
  14. Mar 24, 2015 at 12:28 AM
    JKD
    JKD Well-Known Member
    NEVER install a higher amp capacity fuse unless you know and have verified that all components of the circuit can handle the higher current.
    Eventually some other component becomes the fuse-able element, and then you have a fire.
    Track down the problem in the circuit until you know the cause of the over-current (or short circuit) condition, then fix it.
  15. Mar 24, 2015 at 2:38 AM
    #35
    skipperducker
    Nova Scotia
    Alright.. I've traced the solid green wire from the grey connectors carefully up to the brake like bulb on each side, I can't see a problem
  16. Mar 24, 2015 at 3:12 AM
    #36
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's definitely something you did. Recheck your work until you get sick of starring at it.
  17. Mar 24, 2015 at 3:37 AM
    #37
    skipperducker
    Nova Scotia
    If its popping a fuse, there must be two wires crossing right? So it could be that, but I would have seen it if there was. So maybe it is within the socket...
  18. Mar 24, 2015 at 10:55 AM
    #38
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm telling you install the fuse without installing a tail light. If it does not pop the problem is when the harnesses are hooked up.
  19. Mar 24, 2015 at 12:28 PM
    #39
    skipperducker
    Nova Scotia
    So put in the fuse, and don't hook up the new tail lights or put in the old ones, just leave it open right?
  20. Mar 24, 2015 at 12:33 PM
    #40
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    Install new fuse with taillights out - plug old taillights (ones that you know work) in, see if fuse blows. If fuse doesn't blow - install new taillights.
    if fuse blows with new taillights installed and not the old ones, there's a problem with your new tails.
