Tail lights out.Don't know why
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrdPETE, Apr 19, 2010.
  1. Aug 27, 2013 at 8:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a problem with the Trailer Wiring, not the hitch wiring.
  2. Aug 27, 2013 at 8:19 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    yeah, I'd be willing to bet that somewhere along the trailer the insulation on some of the wiring has worn down and is making contact with metal.
  3. Aug 27, 2013 at 11:40 PM
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    Thanks for the feedback. I believe it is the hitch wiring because this happened with two different trailers and boats. I think I will take it in to the place that installed the hitch and wiring and see if they can track down a bad wire of connection.
  4. Aug 28, 2013 at 4:03 AM
    Hubs
    Hubs Well-Known Member
    Cut the brown(ground) wire to trailer and that should do it!
  5. Aug 28, 2013 at 10:43 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I didn't catch that it was two different trailers... :eek:
    Yeah I think they got something crossed up in the hitch wiring...
  6. Aug 29, 2013 at 6:49 PM
    Silvert
    Jeff
    Wisconsin
    Well, today while convinced the problem was in my trailer wiring I went to the hitch and wiring installer. They are a reputable outfit. They searched the wiring under the truck, could find no questionable areas. We decided to replace the wiring assuming the "brain" was bad. I was only charged for parts.The work was complete I went home, made a too quick visual inspection of my trailer, hooked it up and immediately blew the fuse for the tail lights. Now I assume it best to replace all the the trailer wiring for the trailer here and do the one up north the next time I am there. Does anyone think it could be something else?
    Thanks. getting poorer and still can't use my boat and trailer.
  7. Aug 30, 2013 at 12:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It could still be possible to have two trailers with shorted wiring... I would give it a look. Do you own a Multimeter of any kind you could check for a short to ground in a few minutes on the trailer wiring.
