Tail Pipe Removal, on Stock Exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oildriller, Feb 15, 2013.
  1. Feb 15, 2013 at 1:03 PM
    oildriller
    oildriller [OP] Active Member
    Dean
    Shreveport, Louisiana
    Tacoma, TRD/Off-Road, 4X4
    Bilstein 5100 Series Struts & Shocks (Struts set 2.25", Stock Coil-overs). 1" Rear Leaf Spring Blocks. Throttle Body Spacer. K&N, High Flow-Air Filter. Toyota, OEM, TRD, Cat Back Exhaust (tail pipe cut off, behind muffler, installed 3"OD X 5"L X 45 deg, turn down, dumped prior to axle). Toyota, OEM, Running Boards. Bora, 1" hub-centric wheel spacers. Mud flaps & emblems removed. Satoshi grille (by Brian Roadruck).
    2011, Tacoma, TRD, Off-road.
    If I cut-off the stock exhaust pipe, 4'' behind the stock muffler & install a 7''L-9''L, turn down, angled towards the passenger side wheel -- will there be a noticeable increase of sound (idling, or, traveling at speeds above 35 mph)??
    Is there any increase in fuel mileage, or, overall performance??
    I am not interested in installing a cat back system!!
  2. Feb 15, 2013 at 1:06 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    If you cut it after the muffler it won't do anything but look like shit :notsure:
  3. Feb 15, 2013 at 1:10 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea doing anything after the muffler isn't doing much. Swap out the muffler if you want more noise. You don't have to do an entire cat back system.
  4. Feb 15, 2013 at 1:12 PM
    650H1
    Michael
    VA
    If you don't want an entire cat back system just leave it alone :notsure:
    Op, why the hate for cat back systems? I am more than happy with the trd exhaust...
  5. Feb 15, 2013 at 1:21 PM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    I've seen plenty cut right after the axle, I did mine cuz it got smashed on a rock no difference in mpg maybe a tiny bit louder but was illegal in Utah. I now have a new muff and like it much better. You won't gain any performance by cutting it, and some state law forbids the exhaust to exit under the vehicle it must exit outside the parameter to prevent it from entering back into the vehicle
  6. Nov 22, 2014 at 3:20 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Funny since we are talking about trucks and the bed is the only place the exhaust fumes would go.
  7. Nov 22, 2014 at 7:03 PM
    Arkansas30
    Arkansas30 Well-Known Member
    Conroe, Tx
    2014 Titan Pro4x
    I can see it being loud if it's trd catback.
