tail pipes???
Discussion in 'Performance and Tuning' started by das56170, May 20, 2008.
  1. May 20, 2008 at 4:46 PM
    das56170
    das56170 [OP] Well-Known Member
    Orange County
    2007 Tacoma Access Cab 4X4 SR5 (sold), 2002 Tundra Access Cab 4x4 SR5, TRD Offoad
    Tacoma - Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    Just wondering how important the tail pipes past the muffler are? I have a flowmaster 40 series cat back dual exhaust. The two pipes come out of the muffler and turn down after the rear axel. The problem is that i'm trying to do the spare tire mod so I can fit a bigger tire in the spare compartment. The tail pipes get in the way. How much will it affect peformance or sound if I cut a few inches off the tail pipes. Or on the other hand how much will the performance and sound be affected if I cut the pipes off about a foot past the muffler?
  2. May 20, 2008 at 4:56 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    It will grow louder. My buddies and I do this alot on our older cars usually just put a turn down directly on the muffler.
  3. May 20, 2008 at 5:23 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Run them out one side right in FRONT of the rear tire 'nascar style':cool: you'll definately stand out here AND they'll give admirers the focal point where all that cool sound comes from:)
  4. May 20, 2008 at 6:03 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Turn them around and run them out of the FRONT of the truck! That's so different I'm surprised Nate hasn't done it yet.
