Tail, reverse, and tag lights all out
Discussion in '1st Gen. Tacomas (1995-2004)' started by Crocsandlongboards, Mar 30, 2018.
  1. Mar 30, 2018 at 2:11 PM
    Crocsandlongboards
    Crocsandlongboards [OP] New Member
    97 Tacoma LX 4x4
    Hello all,
    As the title says, each of these sets of lights are out on my 97 tacoma. All other lights work, including brake lights and rear signals. Dash lights also work. The only thing I have done to help diagnose the problem is put my finger on the relay labeled 'tail' under the hood while switching on the lights. There is a click when I do this, not sure if that tells me anything.
    Any help is appreciated!
  2. Mar 30, 2018 at 4:15 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Did you check the fuse?
  3. Mar 30, 2018 at 4:34 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    Under the carpeting just to the right rear of the passenger seat is the connector from the front to the rear wiring harness. The wiring passes through a hole in the floor from inside the cab to under it at this point. All of the lights on the rear of the truck go through this harness. Maybe it is partially disconnected. To check it you'll have to remove the passenger seat, door sill trim plate, and pull up the rug a little. If the plug looks good, chances are you have some open wires in the rear harness. My truck kept blowing the fuse for the taillights, dashlights, license plate lights. Emergency flashers also were DOA. There were 3 wires in the rear harness shorted together. My truck is an'03 Hilux, but the wiring layout is exactly the same as 1st gen Tacos. Good Luck.
    - JAMES
  4. Apr 2, 2018 at 6:16 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I had this happen as several other folks. In my case the trailer wiring splitter box failed. Replaced it and all fixed. Those lights are all on the same circut. Check to see if you have trailer a trailer wiring harness (includes splitter box) installed.
  5. Apr 2, 2018 at 12:55 PM
    Glamisman
    Glamisman Well-Known Member
    hope this helps. It is for a 2000.
