Tail, temp, obd short
Discussion in '1st Gen. Tacomas (1995-2004)' started by Black Hills Tony, Oct 28, 2017.
  1. Oct 28, 2017 at 10:02 AM
    Black Hills Tony
    Black Hills Tony [OP] Active Member
    Joseph, Or
    03 TRD 4WD
    Tail lights, temp guage, and obd2 stopped working all at the same time. It's either a coincidence or a short that involves all three.
    All fuses look good. I jumped the taillight relay port in the under hood fuse box to see if maybe the relay was bad. No dice.
    Before I got to town on this problem and tore in to wiring under the dash, I was hoping to get some clues from you all.
  2. Oct 28, 2017 at 1:07 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Unless your clutch or brake pedals are rubbing wires or rodents chewed things doubtful your issue is under the dash
    No Tail lights what about the front marker lights and dash lights??
    The OBII system Fails to connect
    A short causes circuit protection to open or things to burn and melt to the circuit opens .
    A open circuit the circuit no longer works
  3. Oct 28, 2017 at 1:46 PM
    Glamisman
    Glamisman Well-Known Member
    looks like there is a 50 fuse in the junction box...
  4. Oct 28, 2017 at 3:47 PM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    Markers and dash work. I don't follow the rest other than to say I agree.
  5. Oct 28, 2017 at 4:00 PM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    The one that corresponds to j/b 50a looks good.
  6. Oct 28, 2017 at 4:04 PM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    Ok. Separate issues. Found the bad taillight wire
