Tailgate Anti theft device
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by christian06, May 31, 2019.
  1. Feb 15, 2021 at 6:36 AM
    #381
    oliveira
    oliveira New Member
    Carlos
    Toyota Tacoma
    How do I buy one of these brackets? I'm assuming they fit a Tacoma 2021?
    Thanks
    Carlos
  2. Feb 15, 2021 at 6:55 AM
    #382
    TeamFruitcake
    TeamFruitcake Well-Known Member
    Nacho
    Miami
    2021 TRD Pro (RIP)2015 DCSB TRD OR
    Click his name then start a conversation
    click his name then start a conversation.
    vorkuta775 likes this.
  3. Feb 15, 2021 at 1:13 PM
    #383
    christian06
    christian06 [OP] Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    Yes they fit a 2021, send me a PM for details
  4. Feb 20, 2021 at 2:04 PM
    #384
    TeamFruitcake
    Nacho
    Miami
    Took 2 mins to loosen the bolt and 30 seconds to install.
    Looks great! Material and power coat is top quality.
    Grossomotto likes this.
  5. Feb 20, 2021 at 3:07 PM
    #385
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Pm me price for 3rd gen to 92585 thanks
  6. Feb 20, 2021 at 3:54 PM
    #386
    Tacomarama
    Tacomarama 2021 DCS AG
    Charlie
    AG2021 OR TRD DCSB
    Well, my devise won’t turn into position. It looks like the circular part is too small. I also couldn’t remove to torx screw even with the punch and hammer trick and now the screw is stripped. Anyone know any way I can remove the stripped screw? Thank you.
  7. Feb 20, 2021 at 6:51 PM
    #387
    christian06
    Cali
    That's strange cause each and every one are test fitted to make sure it is top notch.
    I do offer a full refund, PM for details
    bulalo likes this.
  8. Feb 25, 2021 at 1:22 PM
    #388
    Darthbane66
    Darthbane66 New Member
    Hi there, just saw this and am interested in purchasing one. please advice on how to go about doing this. Thank you
  9. Mar 13, 2021 at 7:44 AM
    #389
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    San Antonio "5" or Mexico "3" built?
    My VIN starts with 3, Mexico build. When they did the seam sealer the but a ton of it around the corner. The bracket doesn't slip in as it should. I could remove the tailgate and razor shave that seam sealer, but cuts through the paint when you do that. So I'll use Christian's bracket as a template, and make a unit from 4130 tubing to duplicate the function.
    Not the best photo, but seem the sealer was thin; less than 1/8" inch on the flat, but super thick like 3/8" on the corner.
    rubiconjp likes this.
  10. Mar 14, 2021 at 4:24 PM
    #390
    Tacomarama
    Charlie
    AG2021 OR TRD DCSB
    Mine is built in Mexico. After many attempts, I was able to slip the bracket in. Unfortunately, I stripped the screw on my tailgate and can’t take that devil of a screw out. Tried impact driver and stripped screw removal kits but no go. I’m going to take a break before totally calling it quits.
  11. Mar 14, 2021 at 6:07 PM
    #391
    roundrocktom
    Same here. Used a stainless still shim, so I could get the bracket in. Stripped the head of the torque screw (T40). I did get the electric tailgate lock installed.
  12. Mar 15, 2021 at 5:52 AM
    #392
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    IMO, since there have been reports of the Torx screw getting stripped perhaps the vendor could supply a SS Torx screw with the anti-theft device?
  13. Mar 15, 2021 at 7:02 AM
    #393
    christian06
    Cali
    I do offer a stainless T45 screw
    oostroma[QUOTED] likes this.
  14. Mar 16, 2021 at 8:37 AM
    #394
    jdm55
    jdm55 Member
    Dependsonhermood
    Indiana
    2006 Red Tacoma PreRunner, DCSB, 4L, SR5 TRD
    Chris.....I sent you a PM for purchasing one for my 2006 DCSB
  15. Mar 16, 2021 at 8:53 AM
    #395
    roundrocktom
    Great product, highly recommended.
    Got the bracket and SS Torx screw. I stripped the OEM one trying to get it out. Time to dig out my reverse twist drill bit (use a dull one, so heat and vibration help back out the screw. Having a T40 Torx strip on me seems like they used Loctite RED on those hinges.
  16. Mar 17, 2021 at 8:21 PM
    #396
    john_lim
    john_lim Well-Known Member
    Texas
    17' DCSB TRD OR 4x4
    pp sent
  17. Mar 18, 2021 at 9:23 AM
    #397
    christian06
    Cali
    Thx my friend
  18. Mar 29, 2021 at 1:49 PM
    #398
    BigAls_Voodoo
    BigAls_Voodoo New Member
    2019 Voodoo Blue Toyota Tacoma TRD Pro
    Absolutely incredible product and gives me the piece of mind when I forget to manually lock my tailgate. Thank you @christian06 for an amazing product and helping me out! When removing the old screw as well as installing the new tamper proof one I opened my tailgate about half of the way and then was able to fit my ratchet in there and was able to get it out no problem but it did let out a terrifying shriek when I first was able to break the screw loose but otherwise effortless install.
    I opted for the T45 tamper proof screw and painted it black to have a more refined finish on the tailgate as well as went with the Blue Powder Coat and I am extremely satisfied with how it turned out.
    I went ahead and clear coated everything to try to make everything less likely to rust but only time will tell on that.
  19. Mar 29, 2021 at 2:43 PM
    #399
    christian06
    Cali
    Thx for the kind words my friend, the T45 is stainless so it wont rust, but I do like it painted, I should have powder coated it as well, hmm
  20. Mar 30, 2021 at 9:10 PM
    #400
    john_lim
    Texas
    17' DCSB TRD OR 4x4
    I feel more at ease with having this part installed. I have been telling all my buddies about this! Glws!
