Tailgate antitheft hose clamp mod help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewGuyJosh, Nov 28, 2013.
  1. Nov 28, 2013 at 7:18 PM
    NewGuyJosh
    NewGuyJosh [OP] Well-Known Member
    So I found the post that discusses this mod but it appears the videos or whatever were in the post no longer work. Can any buddy post or link me to a how to on this?
  2. Nov 28, 2013 at 7:21 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
  3. Nov 28, 2013 at 7:24 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    :annoyed: Seriously?
    Put a hose clamp on it... :confused:
  4. Nov 28, 2013 at 7:28 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
  5. Nov 28, 2013 at 7:28 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Sometimes visual stuff helps.
  6. Nov 29, 2013 at 5:39 AM
    Pan704
    Pan704 Active Member
    Rich
    Charlotte, NC
    PreRunner SR5
    Maybe he doesn't know anything about plumbing. I know I don't always remember the correct names of parts.
    Easiest place to find a turn-key hose clamp is at an auto parts store. I found they had more of the smaller vehicle sizes as well as actual turn-key versions. If you want to look at walmart or a hardware store, it'll be in the plumbing section. But they are more likely to just have the standard version with a flat head screw instead of a "turn-key."
  7. Nov 29, 2013 at 7:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes...a hose clamp. It's a deterrent. It'll take a thief a hell of a lot longer to get a hose clamp off to steal the tailgate than the 10 seconds it would take without it.
  8. Nov 29, 2013 at 9:37 AM
    Joe D
    Joe D .
    Newguyjosh (OP),
    Please don't let a random comment stop you from enjoying being a member on TW. We all brain farts and sometime they just come out as unwelcoming comments. Stick around and you'll find plenty of people willing to constructively contribute.
  9. Nov 29, 2013 at 9:38 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
  10. Nov 29, 2013 at 9:46 AM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Don't use the cheap Auto Zone clamps. They will rust. Get a Mercedes clamp.
  11. Nov 29, 2013 at 10:03 AM
    ponchosportal
    ponchosportal Well-Known Member
    Kansas City
    2014 DC TRD TOW
    Tailgate reinforcement, mud-flap removal, weathertech floormats, Pop-N-Lock, ARK Power Pak, Bed-rail shovel mount, Hose-clamp tailgate, equalizer WD hitch, Firestone Ride Rite Air Bags w/Daystar cups,
    The clamp in the photo can be turned so it faces upside down and then can only be removed from underneath .........taking even longer to remove/steal than the way it is positioned.
  12. Nov 29, 2013 at 10:06 AM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    ^^^ You'll be laughing - until next year, when your cheap ass clamp is rusting your tailgate hinge.
  13. Nov 29, 2013 at 10:18 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    If it rusts through, I can swap a tailgate in 25 seconds in a parking lot. :D
  14. Nov 29, 2013 at 12:15 PM
    Janster
    Jandy
    Lancaster, PA
    :rolleyes: Cheap clamps and replace them once a year.
    But, if it were me (and they'd fit)..... I'd have one of these on it.
  15. Nov 29, 2013 at 5:27 PM
    NewGuyJosh
    Thanks for the help guys got it done with the clamps from the auto parts store
  16. Nov 29, 2013 at 6:00 PM
    marktmaxwell
    marktmaxwell Member
    Mark
    Fort WOrth
    12 Tacoma
    Stainless steel clamps are available all over, I.e. Lowe's, Homes Depot' Ace Hardware, etc . . .
