Tailgate Assist On An '09 Anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rickochet, Mar 24, 2009.
  1. Mar 29, 2009 at 7:01 AM
    #41
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    My Redline Hood struts took a few revolutions to break in. At first, the chambers didn't assist until it was further up. After about 10-15 open shuts, they really started working like they should.
    Glad it worked for you and your wife.
  2. Mar 30, 2009 at 9:58 AM
    #42
    [eric]
    [eric] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    mine is the same and the safety cable gets stuck on the right side of control arm. the pinching has ripped the rubber around the safety cable. my solution to the problem was to wrap a sh1t ton of duct tape around the cable. the duct tape pushes the cable away from the "pinching spot" and closes properly. after two days, the duct tape is already starting to warp and is going to be at best a very temporary solution.
    when i open my tailgate now it opens fast for about 1/3 of the way. the rest of the way opens ever so annoyingly slow. it probably takes about 20-30 seconds for the remainder to open.
  3. Feb 26, 2011 at 11:52 AM
    #43
    bonsai3s
    bonsai3s Active Member
    Fresno, CA
    09 TRD, Off Road, Prerunner
    I'm installing the EZ 43601 this morning...it was easy following the photo instructions. (I couldn't believe it, I was 2 easy steps from finishing the install) However, when I got to the size 40 torx bolt on the tailgate, (it's on tight), that I managed to strip the bolt (40 torx became zero torx). I know I'll have to replace this bolt but I could use some ideas on how to remove it first. I'm stuck. Thanks.
  4. Feb 26, 2011 at 1:18 PM
    #44
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    First make sure it was the bolt head stripped and not the torx tool.
    Put a punch inside the bolt and give it a few whacks. Might break it loose.
    Maybe try an impact driver like this: Try using one of the larger Phillips bit. Set it on reverse and whack it with a hammer. Another idea is to get a sharp chisel and get a bite in the outside edge and see if the bolt will budge. Or use one of the little cutting wheels in a Dremel tool and cut a slot for a flat blade screwdriver. Salty swearing while doing the above will also assist in the bolt removal.
    Last resort is to drill it out and remove it with an EZ out. I say last resort because if the EZ out breaks you are screwed.
  5. Feb 26, 2011 at 1:26 PM
    #45
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I read somewhere that the torx bolts on the tailgate for '09+ are tack-welded. Mine wouldn't budge at all.
  6. Feb 26, 2011 at 1:32 PM
    #46
    Rickochet
    Rick
    Kentucky
    The bolts on my '09 came out with no problem. Maybe depends on the plant where there were built. Mine came from the Freemont CA plant.
  7. Feb 26, 2011 at 1:34 PM
    #47
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Hey Rickocet
    Nice job keepin' an eye on an old thread
    Just read in the Dee Zee Group Buy thread,
    You and Joe B removed the Dee Zee EZ Down almost 2 years ago
    Any update on that or have you found a better product?
    I was interested in Redline Tuning's EZ Down,
    But doesn't fit newer than 2007 if I recall.
    Think that was due to Tailgate reinforcement upgrade,
    which decreased the space needed for the EZ Down
    I'd still like something like either of them
    CC
  8. Feb 26, 2011 at 1:40 PM
    #48
    KenLyns
    Belly of the Beast
    All the 2nd gen. beds are made in Baja Calif., Mexico, regardless of final truck assembly location. You probably just have the earlier design. Was your truck built in late 2008 or in 2009?
  9. Feb 26, 2011 at 1:40 PM
    #49
    Cape Codder
    Jack
    KenLyns
    If that's the Belly of the Beast in your sig,
    I'd love to meet the Beast :wink:
    CC
  10. Feb 26, 2011 at 1:48 PM
    #50
    Rickochet
    Rick
    Kentucky
    I subscribe to all threads I participate in and get emails when someone replies on an old one. I still have the EZ Down kit but have not reinstalled it. I miss how it lowers the tailgate but my wife has limited arm strength and has difficulty raising it since you are fighting against the cylinder.
  11. Feb 26, 2011 at 1:50 PM
    #51
    Rickochet
    Rick
    Kentucky
    I bought my '09 in October '08.
  12. May 3, 2011 at 12:29 PM
    #52
    chebz
    chebz New Member
    chebz
    az
    pre runner 2WD
    bought EZ down at checkers for $21.00, had modify the brackets that comes with it a little bit and add replaced some screws... result was awesome....
