Tailgate cables
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nick_Taco, May 19, 2009.
  1. May 19, 2009 at 9:15 PM
    Nick_Taco
    Nick_Taco [OP] Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    My passenger side tailgate cable snapped earlier today, just ordered two new ones so the driver side won't give out too.
    It seems fairly simple, you just unhook the part of the cable attached to the gate and unscrew the top part, is that correct?
    Any tips?
    Thanks :D
  2. May 19, 2009 at 9:27 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    yep, its that simple. my passenger side cable went out a couple of months ago and i replaced both sides at the same time for the same reason as you.
    i did it in the parking lot at school in like 10 minutes.
    screw the top part on first, then hook the other end up to the tailgate. makes it a little easier because if you did it the oother way, you'd have to support the tailgate as you are screwing it in.
  3. May 20, 2009 at 3:08 PM
    Nick_Taco
    Nick
    Maryland
    I went out today to take off the broken cable (new ones come tomorrow) and the screw wont even move.
    I've tried everything, nothing seems to be working :(
  4. May 20, 2009 at 3:13 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    So even if the tailgate didn't suck & bend then there'd be this anyway. JFGR8(Just fuckin great) Kinda makes reinforcing the tailgate pointless unless using the oldschool flat folding metal bars like used to come on older ones. Hooray for more underengineered nonsense!
  5. May 20, 2009 at 3:15 PM
    pittim
    Pennsyltucky
    Boujee Prius
    This is in the first gen forum. Our tailgates don't bend :p ;) :D
  6. May 20, 2009 at 3:36 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Well, I come from 1st gen hilux where nothing bent nor did it have cables to break or frames that rusted through in less than 30 yrs :p :D Guess we both have less quality but more features.
  7. Dec 8, 2009 at 9:08 AM
    saltymike
    saltymike Member
    I'm having the same problem. did you find a good way to remove the old screw besides flathead and a hammer?
  8. Dec 8, 2009 at 9:13 AM
    pittim
    Pennsyltucky
    Boujee Prius
    is the screw head stripped or is it stuck?
    if its stripped, use a grinder to cut notches in the head so it has two flat sides (looks kinda like this (_))
    if its seized, spray some anti seize on it (PB, liquid wrench, etc) and let it sit.
  9. Dec 8, 2009 at 10:35 AM
    saltymike
    saltymike Member
    luckily it's not striped it's just seized. i'll try to get some spray for it. wish pb meant peanut butter cause i've got some of that.
  10. Dec 8, 2009 at 10:48 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I just did mine Sunday... I used an impact driver and would not budge it. I put a air impact on it.. still nothing.. I sprayed it down with IN-Force on both sides (taking the tail light out) still nothing... It was about to strip the head of the screw... So I got out my handheld torch. Its a bottle of Map gas with a torch handle on it.. Headed the bolt up from the tail light side... the bolt unscrewed by hand then...
  11. Dec 8, 2009 at 10:50 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    by the "In- Force" is kinda like PB Blaster, only better.
  12. Dec 8, 2009 at 5:49 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    did mine a few months back i just used a #3 phillips bit and my cordless impact gun and the thing just popped out. i would think that if you didn't have an impact, a good drill would work.
  13. Dec 8, 2009 at 9:00 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    those bolts are in there pretty tight, not seized per se...
    when i tore my truck apart to build the rear end, i used those torx drill bit heads with the socket and a breaker bar for the initial break-loose...
