Tailgate Comfort Mod - Foam Inserts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vecdran, May 31, 2020.
  1. May 31, 2020 at 6:38 PM
    vecdran
    vecdran [OP] Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Like a lot of other people here, I find the tailgate really painful to kneel on, as well being slippery and a bad surface to place objects on (drinks, plates, etc). There are some plastic and metal replacements out there, but they are expensive, and some are of questionable quality.
    I decided to DIY a solution. For about $25 in materials, I was able to significantly improve how comfortable the tailgate is, as well as making it somewhat non-slip.
    I used a foam exercise mat tile I had lying around and a $15 roll of 1" 3M 5952 VHB foam tape. Cutting the foam mat into 1.5"x12.25" strips with a box cutter, I then beveled the edges 45 deg with a sharp pair of scissors. I cleaned up the tailgate really well with isopropyl alcohol, then I used a 3M Primer 94 adhesion promoter pen (optional) on the tailgate to ensure a strong bond. A rubber hand roller helped ensure the VHB was laid down evenly.
    For the slots that had screw heads, I pressed down hard to get an impression, then I scored and cross-hatched the foam and plucked out a divot.
    While this likely won't hold up on any beds that see hard use (lumber, tools, etc.), it will suit my purposes just fine. Kneeling is a lot more comfortable, drinks don't topple over now, and my stove doesn't slide around. I pulled at one and it felt pretty secure. You'd have to be trying to pull one up.
  2. May 31, 2020 at 6:40 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    FANTASTIC MOD!!
    This is now on my list of things-to-do. Thank you for coming up with this and sharing it!
    a400ryan, WhiskeyOso, P-Dawg and 10 others like this.
  3. May 31, 2020 at 6:43 PM
    Flowie
    Flowie Well-Known Member
    2017 TRD OR
    None yet
    Thats a great idea. Thanks for for sharing it.
    Junkhead and vecdran[OP] like this.
  4. May 31, 2020 at 7:36 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I bet Liquid Nails would hold those strips on till they rotted off.
    C41n and Skydvrr like this.
  5. May 31, 2020 at 7:40 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    @MESO quit fuckin around and press out a mold of a million of these inserts :D
  6. May 31, 2020 at 7:41 PM
    gemiv19
    gemiv19 Well-Known Member
    Ted
    Central Point OR
    2024 DCLB TRD OR Blue Crush
    Totally Stock for now
    Pretty cool and cheap mod.
    boston23 and toofast4u752 like this.
  7. May 31, 2020 at 7:43 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Awesome mod. I might try this for my 2010
  8. May 31, 2020 at 7:50 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    This is amazing. Multiple color options too on Amazon
    Lucifer1 likes this.
  9. May 31, 2020 at 8:13 PM
    vecdran
    Jeremy
    Kirkland, WA
    Thought crossed my mind. With a proper mold, you could make something that looked seamless. Thing is, would people be willing to pay $60-70 for this? Also keeping in mind you'd have to make two molds, since four of them are different with the torx screw head. Or just make them all screw head compatible I guess.
    I contemplated using JB Weld, but I decided I wanted something removable if need be. 3M VHB tape, while messy if aged, will still come up fairly easily with the right tools
    davidstacoma, tonered and C41n like this.
  10. May 31, 2020 at 9:07 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    People pay 230$ for a POS. Don't screw shit in, make wedges that are high enough to clear bolts AND non bolts. There will be some ridges but not bad.
    Malvolio likes this.
  11. May 31, 2020 at 9:46 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    That's crazy, I no shit had the same idea after reading one of the mountain hatch threads. I figure someone with the know hows of a 3d printer could print out a mold of the ridges. I know nothing about 3d printing, I would think it's an easy shape to replicate.
    Lucifer1 and tonered like this.
  12. May 31, 2020 at 9:50 PM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    Damn watson i think you may be on to something here
  13. Jun 1, 2020 at 2:53 AM
    FourWD
    FourWD Well-Known Member
    19 Tacoma DCSB OR TRD
    Sub for the idea. Thanks :D
  14. Jun 1, 2020 at 3:09 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I like it!
    Hmm . . . I think that I know where I can get a scrap of cushioned diamond tread pattern rubber mat. :homer:
  15. Jun 1, 2020 at 3:37 AM
    KVTaco
    KVTaco Well-Known Member
    Kudos, well done!
  16. Jun 1, 2020 at 8:32 AM
    18BRMTRDSportTaco
    18BRMTRDSportTaco Well-Known Member
    Sachse, Texas
    18 BRM TRDS DCSB
    TRD Pro SEMA wheels, 265/70/17 Falken Wild Peaks, OEM TRD Pro Grill, OEM Toyota Tundra LED foglights, Morimoto 5500K HID w/Hylux ballast, OEM Black Emblem Overlays.
    Pretty cool idea! Way to think outside the box. I may just have to try this.:cheers:
  17. Jun 1, 2020 at 9:11 AM
    COS_TACO
    COS_TACO Well-Known Member
    Colorado
    2018 SR5 ACLB V6 4x4
    Very awesome idea! Hey @vecdran so is that mat dense enough that when you actually get up there on your knees... it supports you enough that it doesn't compress enough that you still feel those dang troughs? I know some of those mats are dense when standing on them - but my weight distributed throughout my footprint is much more spread out than concentrating weight over a few sq inches with me knee. Just curious. This mod just shot up pretty high on my wish list.
  18. Jun 1, 2020 at 9:13 AM
    vecdran
    Jeremy
    Kirkland, WA
    For me they're dense enough. There's some squish, and I wouldn't drop a knee hard or anything, but it's enough to take it from "FUCK OW" to "hmm, mildly uncomfortable".
  19. Jun 1, 2020 at 9:15 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Great idea, I'm gonna try to find the time to make this happen
  20. Jun 1, 2020 at 9:16 AM
    COS_TACO
    Colorado
    Thanks for the feedback... definitely looking to address the "fuck ow" and I'd probably take "mild uncomfort" for $25
    Also - love the two-tone look it gives, nice bonus there.
    pianoman8t8, Tullie D and vecdran[OP] like this.
