Tailgate Comfort Mod - Foam Inserts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vecdran, May 31, 2020.
  1. Jun 1, 2020 at 9:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is a method called urethane casting:
    https://www.stratasysdirect.com/technologies/urethane-casting
    I wonder if something like that could work to kick out these parts at a lower cost than metal mold?
    Nice work, @vecdran !
    Tullie D and vecdran[OP] like this.
  2. Jun 1, 2020 at 9:52 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I have a ton of alginate at home (used to make dental molds) I might order some more silicone and see about making a mold of these channels that I can then cast in a foam rubber.
    I can pour the alginate into the surface, then when its set pull it out and use the silicone to make a mold of that. Then I would have a silicone mold of the channels that I could make new ones with. I might have enough silicone at home now to make a hard mold with (thin layer of silicone with a hard shell)
  3. Jun 1, 2020 at 9:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice!
    This could get interesting.
    :cheers:
    Skydvrr and Tullie D like this.
  4. Jun 1, 2020 at 10:03 AM
    rskinz
    rskinz Well-Known Member
    I like it!
    Tullie D likes this.
  5. Jun 1, 2020 at 10:05 AM
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
  6. Jun 1, 2020 at 10:26 AM
    5nahalf
    Erik
    Minnesota
    Thinking about this, I bet I could just take the tailgate panel and dump the foam rubber right into the channels.... they are slick enough already that I bet the parts would just pop right out.
    4x4spiegel, Tullie D and tonered like this.
  7. Jun 1, 2020 at 10:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With some VHB on the bottom, that might have them being just proud enough.
    4x4spiegel and Tullie D like this.
  8. Jun 1, 2020 at 2:02 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yah... I was wondering similar with how much rubber silicone would be needed to fill and let dry in each one. Then you just sell the rubber pieces/get them made.
    tonered[QUOTED] likes this.
  9. Jun 1, 2020 at 2:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The process that I linked is not quite that. It is where you make a less expensive urethane mold for casting parts versus a metal die for injection molding.
    But, what you are thinking is what @5nahalf is going to try. With how slick the TG surface is, you probably don't need mold release. :D
    SpeySquatch[QUOTED] likes this.
  10. Jun 1, 2020 at 2:49 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Great idea, “ why didn’t I think of it “, somebody needs to run with this.
    Malvolio and tonered like this.
  11. Jun 1, 2020 at 2:57 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    OP, What are you using to span the gap between the bed and the tail gate? I already have the ESI ultimate tailgate seal that helps keep out dust and such. But that extra piece of seal you have in there looks like a great way to make sure stuff doesn't fall down and get wedged between the bed and the tail gate, along with being an extra layer of protection against water and dust infiltration.
  12. Jun 1, 2020 at 4:00 PM
    vecdran
    vecdran [OP] Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    https://www.amazon.com/gp/product/B00BPE4AP6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Cool little bonus, this was the kit I got my 3M Primer 94 pen from, and those are $14/ea on Amazon.
  13. Jun 1, 2020 at 4:04 PM
    fatboyfirebass
    tonered likes this.
  14. Jun 1, 2020 at 5:03 PM
    awynne56
    awynne56 Well-Known Member
    Andy
    2019 Taco trd sport
    front grill pro
    Thank you op Great idea
    Malvolio likes this.
  15. Jun 2, 2020 at 9:09 AM
    #35
    pianoman8t8
    pianoman8t8 Active Member
    Maine
    2006 Tacoma TRD Sport DCLB
    Bilstein 5100's, 285/75-16's, big steel front bumper, Jeraco mid-rise camper shell with rain gutter rail roof rack mounts 4ft cross bars, adjustable front upper control arms, small lift, cab corner delete, bed stiffeners, bed mat, yoga mat foam in tailgate grooves (knee saver), 84" roof cargo rack, uniden 980ssb with firestick antenna, wood sleeping platform on bed rail notches, led cab lights, chrome delete, 140mm computer fan on front camper top window.
    As far as mold making goes, I may know someone with Solidworks (3D modeling) and a full machine shop at his house. (me) LOL...
    gemiv19 likes this.
  16. Jun 2, 2020 at 9:12 AM
    #36
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    What're you doing here?! Get busy!
    Skydvrr and pianoman8t8[QUOTED] like this.
  17. Jun 2, 2020 at 9:23 AM
    #37
    pianoman8t8
    Maine
    Would the mold be something just like a cavity you pour liquid material into, let harden, and pop out? Or, a 2-halves mold you pour material in via sprue? A split mold like that would allow a textured top as well, of virtually whatever texture you want milled into the mold.
  18. Jun 2, 2020 at 9:25 AM
    #38
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Where do I order? :spending:
  19. Jun 2, 2020 at 9:31 AM
    #39
    pianoman8t8
    Maine
    At least the shape of this is very simple. Last one I machined was for these scale wind turbine blades, several yrs ago. (see link for photo of blades: http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.656.7987&rep=rep1&type=pdf )
    Granted this one was a bit fancier, allowed for an air bladder to force the carbon fiber/epoxy weave to be pushed against inner walls of mold, making the blade mostly hollow also. We did a few molds for blades of this rough size back in the, for both air and water mediums. Mater medium blade molds were solid molds though, trying to recall the material we used to mold the blade. Want to say it was a Plasti-dip product, I'll have to do some digging.
  20. Jun 2, 2020 at 9:34 AM
    #40
    pianoman8t8
    Maine
    Also disclaimer, I made these while at a previous employer, not my home shop. But I now have very similar machines of my own.
