Tailgate Comfort Mod - Foam Inserts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vecdran, May 31, 2020.
  1. Jun 2, 2020 at 9:34 AM
    #41
    pianoman8t8
    pianoman8t8 Active Member
    Maine
    2006 Tacoma TRD Sport DCLB
    Bilstein 5100's, 285/75-16's, big steel front bumper, Jeraco mid-rise camper shell with rain gutter rail roof rack mounts 4ft cross bars, adjustable front upper control arms, small lift, cab corner delete, bed stiffeners, bed mat, yoga mat foam in tailgate grooves (knee saver), 84" roof cargo rack, uniden 980ssb with firestick antenna, wood sleeping platform on bed rail notches, led cab lights, chrome delete, 140mm computer fan on front camper top window.
  2. Jun 2, 2020 at 9:38 AM
    #42
    pianoman8t8
    Maine
    Are the troughs the same on the 2nd gen as well? I could get relatively accurate measurements on mine if so, to make a model with.
  3. Jun 2, 2020 at 10:22 AM
    #43
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Ive given this a fair amount of thought. I was thinking that getting some concrete stamps, then pour the liquid into the tailgate panel (removed from the truck and placed on a flat level surface) then placing the concrete stamp on top while its curing. This would end up giving you a stone texture on it.
    The only issue I am seeing with this though is that many materials that could be used would rip very easy. I want to test out a few materials to see what is strong enough, but still soft on the knees.
    tonered likes this.
  4. Jun 2, 2020 at 10:33 AM
    #44
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I just asked if anyone on our local Buy Nothing FB Group had any of the foam pads available, and YUP! I want to give this a try. Now I can just order some of the VHB tape on Amazon and I'll be well on my way!
    tonered likes this.
  5. Jun 2, 2020 at 11:34 AM
    #45
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Excellent idea. Now all it takes is someone with a water jet and an accurate file drawing to market it as a DIY kit
  6. Jun 2, 2020 at 11:38 AM
    #46
    vecdran
    vecdran [OP] Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    That would definitely be the most cost effective way to "do it right". Water jetting foam works really well.
    Malvolio likes this.
  7. Jun 2, 2020 at 11:39 AM
    #47
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The only issue I see with foam is, they'd need to sit proud so that when they compress they're flush. If they start out flush it seems like they'd only help minimally
    Malvolio, tonered and boston23 like this.
  8. Jun 2, 2020 at 11:44 AM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A cast using the existing TG skin with thick VHB would work for this. But, there would be some small gaps around the edges.
    I could live with these gaps if it keeps the price way down.
    Skydvrr[QUOTED] likes this.
  9. Jun 2, 2020 at 11:53 AM
    #49
    Skydvrr
    Nick
    YMH
    Black '17 OR
    No idea what those acronyms are, but based on previous conversations we've had, I trust ya haha.
    tonered[QUOTED] likes this.
  10. Jun 2, 2020 at 11:55 AM
    #50
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    LoL! TG is tailgate. Sorry!
    VHB is the very sticky 3M foam tape that we would use. It comes in various widths and thicknesses. Depending, you can also double the thickness as it really sticks to itself well. Don't do that by accident. There is some shown in the Products box below.
  11. Jun 2, 2020 at 12:00 PM
    #51
    pianoman8t8
    Maine
    You COULD cast directly into the tailgate plastic and ideally (maybe) have no need for an adhesive if you used like an 80A Shore rubber cast. An example process could be: Remove "tailgate skin" in question, mark off existing mounting holes (ear plugs maybe)(or, bolt with a stack of washers or a bushing to make a thru-hole cavity once cast), drill a 0.201" hole an inch or so from each end, drive a 1/4" socket head cap screw so the head is OFF the bottom of the trough, but also below flush with top surface (or pan head, or whatever you feel is adequate), pour in casting material, let harden, remove the washer stack/bushing previously put in, this will allow access to original tailgate skin mounting holes. Now, the rubber sections are held in place by 1 bolt at each end of each trough, via the bolt head that's in the middle of the cross section... Hopefully that makes sense.
    GRANTED, we're talking about 2/3 a gallon of cast material. Probably close to $80 or so...
  12. Jun 2, 2020 at 12:02 PM
    #52
    FishnTx
    South East Texas
    ‘17 OR
  13. Jun 2, 2020 at 1:01 PM
    #53
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    people on TW be like
    And I'm like
  14. Jun 2, 2020 at 1:26 PM
    #54
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    Some extremely clever and compex suggestions. The OP @vecdran has created a very attractive solution for the "FUCK, OWW" problem.
    Here is a much less elegant and simpler, cheaper, and quicker approach:
    MATERIALS: $8.99
    Gorilla Tape (around perimeter)
    3M VHB (under edges only)
    TOOLS:
    (Very Sharp) Utility Knife
    Roller
    Straightedge
    This installation on a 2000 PreRunner with an aftermarket Bed Liner. It adds a small factor of sound and thermal insulation. (Cheap Home Depot door handle and red strap facilitate pulling the tailgate closed from inside)
    ANOTHER APPLICATION,USING $8.99
    The 4-piece anti fatigue foam mat set can be assembled as a square and also as one long rectangle. Three pieces in a rectangle, with a cut-out for wheel-well can be placed as one-half of padding for the floor of the 6 foot bed of the truck. Two in that form will cover both sides of the truck bed floor. Use Gorilla Tape on the seams on the underside for a more permanent construction. Also adds a small factor of sound and thermal insultation.
    C41n, boston23 and tonered like this.
  15. Jun 2, 2020 at 2:09 PM
    #55
    vecdran
    Jeremy
    Kirkland, WA
    Take a look at my photos in the first post. The VHB is enough to get them to sit proud. A casting would be the same.
    tonered likes this.
  16. Jun 2, 2020 at 2:25 PM
    #56
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
  17. Jun 2, 2020 at 5:07 PM
    #57
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I measured mine (3rd gen) at ~3/8" deep (my calipers read .3765)
  18. Jun 2, 2020 at 6:32 PM
    #58
    RNO_TACO
    RNO_TACO Well-Known Member
    Brent
    Roseville, CA
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    A.R.E. Topper with victory topper rack, blacked out exterior emblems, star armor side steps, TRD CAI, TRD Pro exhaust, Method MR305 NV 16in Rims, TRD PRO front grill, Meso coin holder, TRD Pro skid plate, Kings 2.5 coilovers with remote resis front and rear, OME HD Dakar’s, ECGS, LT285/75R16 KM3s, Dirt king UCAs, Meso gas cap holder, Meso blacked out interior kit, TRD start/stop red button, AVS low profile window guards, AVS low profile hood protector, Full LED upgrades inside and outside, decked bed storage system. And I’m sure there’s more I’m missing lol
    This may work as well? Cheap option from harbor freight. Just have to use a box knife to cut to size but the good thing is the adhesive is already there.
    Nice job OP, excellent idea for sure.
  19. Jun 2, 2020 at 6:41 PM
    #59
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    It looks too thin
  20. Jun 2, 2020 at 6:43 PM
    #60
    RNO_TACO
    Brent
    Roseville, CA
    Yeah you’re probably right. Just thinking of inexpensive ideas like the OP. However,
    I think the OP has this idea nailed pretty good.
