Tailgate cord loose on one side, tight on other?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PanzerDivisionBlack, Jul 2, 2023.
  1. Jul 2, 2023 at 1:56 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    OPs check good! lol
    Both tighten at the same tension as the gate reaches length.
    Looks like adjusting the length requires some work.
  2. Jul 2, 2023 at 2:14 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I asked my wife and she said one typically hangs lower than the other.
  3. Jul 2, 2023 at 2:36 PM
    Firn
    Firn Well-Known Member
    White OR
    Holy cow the Toyota apologists are out today.
    It's literally wrong and they have to go on about how it's the op's fault for asking.
  4. Jul 2, 2023 at 3:02 PM
    PanzerDivisionBlack
    PanzerDivisionBlack [OP] Well-Known Member
    Im used to it on this forum, anytime I ask about something, im the one who has the problem, not Toyota lol
    davidstacoma likes this.
  5. Jul 2, 2023 at 3:31 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Panzer man don't call yourself an idiot. You like all the rest of us have questions ,and sometimes concerns.
  6. Jul 2, 2023 at 3:39 PM
    PanzerDivisionBlack
    Appreciate you!
    I know I have dumb questions. I've had 4 trucks in the last 3 years but never had a truck before that just SUVs so it's all somewhat new to me.
    TacoTime55 and ABA180 like this.
  7. Jul 2, 2023 at 3:49 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Can't you disconnect 1 end, twist the cable a half turn, then reattach?
    CaptainBart45 and RIX TUX like this.
  8. Jul 2, 2023 at 5:18 PM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    It's a cable and an ⅛ inch of slack isn't exactly "tons". As long as the tailgate closes normally it's not going to hurt anything, but if it bothers you that much then take it back to the dealer.
    Stevie17 and Chew like this.
  9. Jul 2, 2023 at 8:23 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    no
    Chew likes this.
  10. Jul 2, 2023 at 8:28 PM
    RIX TUX
  11. Jul 2, 2023 at 8:47 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    usmc2msu and RIX TUX[QUOTED] like this.
  12. Jan 5, 2024 at 3:37 PM
    Ayusuf99
    Ayusuf99 Well-Known Member
    Ali
    2021 green tacoma trd off-road
    Stock
    What is the tailgate clamp that may have pulled out , can you upload a photo of the part
  13. Jan 5, 2024 at 3:47 PM
    02hilux
    Planet: EARTH
    The portion of the cable that is clamp at the ends
  14. Jan 5, 2024 at 4:10 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Get the cable stretcher tool and stretch the short one.
  15. Jan 5, 2024 at 4:21 PM
    #35
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    it's ok, we understand.
  16. Jan 5, 2024 at 4:45 PM
    #36
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Tape measure time- check how long the cable is between each or the crimped parts. It’s probably less than a 1/16” difference unless you are a Canuck.:canada:
  17. Jan 7, 2024 at 11:26 PM
    #37
    Ayusuf99
    Ali
    Stock
    Got it , Thanks
    02hilux[QUOTED] likes this.
  18. Jan 8, 2024 at 2:54 AM
    #38
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I don’t see this as a real problem. Many brands of trucks are like this. But, your truck, your call. I did check my 23 Tacoma, both get tension at nearly the same time. However, my left has slightly more tension than the right. Both are tight when my far arse of 225, is sitting on the tailgate.
    Buy a set or take it to the dealer. No way to tell if one is long or one is short.
    https://www.*****************.com/oem-parts/toyota-check-strap-6577004080?c=Zz1ib2R5JnM9dGFpbC1nYXRlJmw9OSZuPUFzc2VtYmxpZXMgUGFnZSZhPXRveW90YSZvPXRhY29tYSZ5PTIwMjMmdD10cmQtc3BvcnQmZT0zLTVsLXY2LWdhcw==
  19. Sep 4, 2024 at 12:40 PM
    #39
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    OP: same issue with my new 2024 Trailhunter. Very annoying. Cables are the same length but the one on the left has maybe 1/8” of slack and stays loose even when I put weight on the tailgate. I was thinking of wrapping something around the left cable eyelet hole to tighten it, but my bigger worry is whether there’s a bigger issue.
    Did you resolve it?
