Tailgate Gap Cover Solution
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 22lunarrocktaco, Mar 15, 2025.
  1. Mar 15, 2025 at 1:09 AM
    22lunarrocktaco
    22lunarrocktaco [OP] Member
    2022 Lunar Rock Tacoma DCLB Off Road
    3.5 lift Camper
    Has anyone found a solution to keep dust out of your camper where the tailgate opens and closes?
    I’ve tried the rubber seals but it didn’t stay on forever.
    Thank you!
  2. Mar 15, 2025 at 5:59 AM
    Redsquirrel
    Redsquirrel Well-Known Member
    I use a rok blok kit on mine but you have to use the paint pen that comes with it. This will etch the bed material so the tape sticks on. Did yours not come with a pen?
    Willy Lump Lump likes this.
  3. Mar 15, 2025 at 8:41 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    To add above, I would also add 3m tape primer 94 to the surface. Comes in a mini quart paint can and brush it on.
    I haven’t done this yet but I bought the 94 for this project specifically.
  4. Mar 15, 2025 at 1:35 PM
    22lunarrocktaco
    3.5 lift Camper
    Is it still on? I wonder why mine didn’t stick. Maybe I didn’t clean thoroughly or the adhesive dried out..
  5. Mar 15, 2025 at 5:52 PM
    Redsquirrel
    ya mine is still going strong and i put it on in January problems so far.
  6. Mar 16, 2025 at 1:25 AM
    22lunarrocktaco
    3.5 lift Camper
    Could you link me? Thank you!
  7. Mar 16, 2025 at 6:06 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    It’s gotta be cleaned, prepped, and when applied it needs pressure to make it adhere. I smacked it with a rubber mallet. I also left the gate done for 24 hours to cure. I’ve done it twice, first one I had to cut off after changing tailgate panels.
  8. Mar 16, 2025 at 6:07 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Does your shell have a positive pressure vent? If not adding one will make a world of difference
  9. Mar 16, 2025 at 6:11 AM
    Redsquirrel
