tailgate handle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Jul 11, 2011.
  1. Jul 11, 2011 at 6:22 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    so over the weekend, something came disconnected or got jammed up with my tailgate handle. now it wont stay closed and is held up with a ratchet strap. i noticed there is a bunch of torx head screws in the plastic cover on the backside of the tail gate. if i remove those will it give me access to the inside of the gate so i can figure out what happened?
  2. Jul 11, 2011 at 6:30 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yes, take the torx things loose and pull up on the edge of the top strip to get the big tailgate piece off then you can see if the linkages came loose or the plastic clippy things holding the rods came undone or broke. It's a flimsy thing and I could see it coming undone with some quick repeated openings.
  3. Jul 11, 2011 at 6:31 AM
    formulabird1997
    formulabird1997 Well-Known Member
    Greg
    shaw afb, sc
    2010 tacoma trd sport
    Kobalt compact tool box, Rear spring tsb
  4. Jul 11, 2011 at 6:44 AM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I recently added the power door lock solenoid to mine. It's easy, but I actually thought the latches on the edges of the tailgate were spring loaded. It sounds to me like maybe a rock or debris got caught in the latches. It should be easy enough to take apart and clean. Tell us what you find.
    RZ Rob
  5. Jul 11, 2011 at 6:59 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Dynolock or PopnLock? Just installed my PopnLock and lock it!
  6. Jul 11, 2011 at 5:51 PM
    danteisme
    South Western PA
    nothing broke, the linkage had some rust on it and wasnt returning to its point. i put a good coat of white lithium grease on all the moving parts. i;m going to try the stuff in those links this weekend i think.
