Tailgate Jam
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kenkrawford, Jul 16, 2007.
  1. Jul 10, 2015 at 10:59 AM
    evan164
    evan164 Well-Known Member
    Evan
    Louisiana
    05 Prerunner SR5
    Added a trailer hitch and the 4 pin connector
    I've done both of those things, and still just won't open.
  2. Jul 10, 2015 at 11:01 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    is it jammed on one side? does the handle open when you pull on it?
  3. Jul 10, 2015 at 11:05 AM
    evan164
    Evan
    Louisiana
    05 Prerunner SR5
    Yep, it's jammed on the left side. When I pull on the handle the right side comes loose. We opened it up so I could look at the mechanism, I tried pulling on it. The wire connected to the latch seems to work, but the latch isn't opening. If that makes sense. We sprayed almost a whole bottle of liquid wrench on the latch, the mechanism, pretty much every where there is some sort of connection
  4. Jul 10, 2015 at 12:50 PM
    ranger098
    Brian
    Minnesota
    Get a crow bar out, im not sure how the wire (also known as a rod, ha) can move without the latch moving. something's locking the latch tho, so it doesnt sound like spray will help.
    I think it's something you'd have to see in person to help any further, so all i can say is good luck and post back with your fix so it helps others in the future!
