Tailgate ladder
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DesertRatR, May 29, 2021.
  1. May 31, 2021 at 5:14 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    When I installed mine, I used red Threadlocker on the bolts. I never said I wasn't paranoid.
  2. May 31, 2021 at 7:13 PM
    DesertRatR
    DesertRatR [OP] My favorite dog is what I got.
    Southern AZ
    2019 TRD 4WD Off-Road
    So I ordered the OEM step from my local dealer Saturday night and picked it up this morning. Took about half an hour to install. The included instructions were fine. I did not use a vise (my vise is way too dinky and 33 ft-lb would probably either tear it off the bench or flip the bench). I used the tail gate as a work surface and held it down with one hand while using my torque wrench in the other (The wrench is 18" long and rated to 160 ft-lb). Bolting it to the bumper mount point wasn't a big deal. The lower bolt was hidden from view so I got it by feel. I did need an extension to torque it to 66 ft-lb, though. The upper bolt was very easy. I set the platform so it mounts to the outside, not the inside. And it holds my sorry overweight hind end just fine.
    Reading about others who needed a breaker bar to remove the bolts concerns me. The truck was rear-ended 2 years ago and the bumper was replaced. Now I am a bit concerned that the dealer collision shop may not have properly torqued the 5 bolts down there. Clearly I was not breaking anywhere near 66 ft-lb when I removed the two bolts. I am guessing it took maybe 15 ft-lb to break loose the bolts. Time to have the bolts checked before there is a problem.
    averagejp and Minny Taco like this.
  3. May 31, 2021 at 7:37 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Mine were tough to break loose, breaker bar was the only way those were coming out. I’d check the rest of them, sounds like they weren’t torqued properly as you said. I’d check your U bolts while you’re under there. Half mine were out of wack from the factory. I forget the ft-lb on them though.
    davidstacoma and averagejp like this.
  4. May 31, 2021 at 8:29 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    Glad you got the step installed! You are right to check the bumper bolts -- better to be safe that sorry. But it sounds like you have that under control (or will shortlY).
    How does the step work for you? Does it meet your needs?
    Congrats !
  5. May 31, 2021 at 8:51 PM
    DesertRatR
    Southern AZ
    Yup. Easy to deploy easy to stow. Easy to climb onto bed.
  6. May 31, 2021 at 9:03 PM
    DesertRatR
    Southern AZ
    I found a lot of torque specs for the 4Runner in . All rear bumper bolt torque is listed as 13 ft-lb. That just doesn’t pass the sniff test. When I get a chance to visit the dealer to comfirm bolt spec I’ll report back.
  7. Jun 1, 2021 at 11:39 AM
    DesertRatR
    Southern AZ
    So a little Google and I uncovered some mechanical engineering facts about installation torque versus removal torque. The latter is less than the former. In both cases there is friction between bolt head and part being bolted as well as in the threads. Tightening also mechanically works the threads, which you don't have when backing off. This all assumes that the parts are clean and not dirty or rusted. My bolts were clean.
    I visited the dealer collision center and they checked the torque for all the bumper attach bolts. Everything is within spec. So no worry about my bumper falling off or otherwise not acting as designed.
  8. Jun 1, 2021 at 12:00 PM
    cop414
    Tim
    Central PA
    Excellent, better safe than sorry :thumbsup:
  9. Jun 1, 2021 at 3:29 PM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Wouldn't you love to be able to [affordably] put one of these on your Tacoma:
  10. Jun 1, 2021 at 3:37 PM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    I always wonder how well those fancy GMC tailgates will hold up over time.... but I do miss those corner steps/bumper cutouts that my Sierra had. In a perfect world, my Tacoma tailgate would be as light as the one on my F250 and my bumper would have the little cutout steps.
  11. Jun 1, 2021 at 5:19 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    GMC probably has a patent on that idea. Otherwise I'm sure others would have followed suit.
  12. Jun 1, 2021 at 6:58 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    until you forget your hitch ball is installed in your hitch, and you lower your fancy step tailgate, and it rams into the hitch ball and wipes out your fancy tailgate...
    LarryDangerfield likes this.
  13. Jun 1, 2021 at 9:36 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  14. Jun 2, 2021 at 4:48 AM
    grandpawmoses
    David
    No money
    I know someone who did just that. 2 week old truck & showing off the "special" tailgate.
