Tailgate latches failing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TacoRidah, Oct 11, 2012.
  1. Oct 11, 2012 at 7:37 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    Is this normal? I used to think someone was messing with my tailgate leaving it semi unlocked (like when you close the car door half way). Last night I go to close it and I found out it was the latches that weren't locking. I can pull it and it will get loose. :mad: I don't open and close it all the time either. hell I BARELY put anything in the bed, when I do, it's not often.
  2. Oct 11, 2012 at 7:39 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Haven't heard of this problem yet... do you think the physical latches are failing?
  3. Oct 11, 2012 at 7:44 AM
    07TacoRidah
    just in case (did a Google image search and it should mainly the handle)
    this is what I am referring to (I don't have the bear claw latch though lol).
    I pulled off the tailgate last night and a little while ago I tried to move the inside part to see if it locks, and it doesn't really move much. looks like it's VERY rusted. I haven't tried the other side though.
  4. Oct 11, 2012 at 7:47 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Check the Latches, clean if necessary, then hit them with some lube. Maybe just binding up being dirty or a lack of grease :cool:
  5. Oct 11, 2012 at 7:48 AM
    07TacoRidah
    tested both sides and it's just one side that won't lock. :( anyone know where to get a replacement besides heading out to the dealership?
  6. Oct 11, 2012 at 7:49 AM
    Delmarva
    Tucson, AZ
    strange... I just looked on rockauto.com and it doesn't appear to have those for sale... :notsure:
  7. Oct 11, 2012 at 7:55 AM
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
  8. Oct 11, 2012 at 8:24 AM
    07TacoRidah
    lol it's called the Bear Claw latch or something. I just did a Google image search of car door latches to get a reference image to what I was talking about so that no one would think it's the handle, which I find odd that the handle showed up as the latch.
  9. Oct 11, 2012 at 8:25 AM
    07TacoRidah
    GOT DAMN!!!!!!!!!! $50 for ONE LATCH!!!!!!!!!! :rant:
  10. Oct 11, 2012 at 8:26 AM
    Delmarva
    Tucson, AZ
  11. Oct 11, 2012 at 8:34 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I highly recommend this place http://www.tacomaworld.com/forum/camelback-toyota-parts/ they are a site sponsor and gave me cheaper prices than I found anywhere else on the net. First thread in the forum currently states any orders over $60 get free shipping as well. :cool:
    Here's the phone #
    Jorge Rios
    877.840.8881 - Toll Free
  12. Oct 11, 2012 at 8:41 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Damn interesting...I hadn't heard of anything like this before...:anonymous: no bueno
  13. Oct 11, 2012 at 8:44 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    If you say you hardly use your tailgate- take off the back panel and see everything is hooked up? Its seems it should not be worn, but it could be defective? Were the latches clean or? Any rust on latches?
  14. Oct 11, 2012 at 8:57 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Your current latch may still be salvageable. I agree w/ PSJ, scrub it up with a pipecleaner to get all the dirt out and then hit it with some lube/wd40 to loosen it up.
  15. Oct 11, 2012 at 9:13 AM
    07TacoRidah
    I took it apart right now, and found the culprit. it's was a small pebble (strangely it's one of them little rocks that look all crystal like... not sure if that makes sense) that got lodged into the latch itself!! :eek: how it got in there is a puzzle to me, but it was inside where the lock is for the latch, it was preventing the lock to snap back like it's supposed to. I poked it out and now going to clean the latches. Both of them look old, some rust on the latches but they still work. Just have to clean them like you said. Thanks guys. :cool:
    sorry for the crappy cell phone pix. :(:eek:
  16. Oct 11, 2012 at 9:17 AM
    Delmarva
    Tucson, AZ
    wowzas... good job :)
  17. Oct 11, 2012 at 9:33 AM
    07TacoRidah
    RIGHT!!! lol was thinking these trucks go to sh*t after a while. smh :p
  18. Oct 11, 2012 at 9:40 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
  19. Oct 11, 2012 at 9:45 AM
    ziggynagy
    Stoughton, MA
    :woot:
    Good job! The stone is probably quartz.
