Tailgate Light Bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Anchovy, Dec 6, 2018.
  1. May 21, 2021 at 7:12 PM
    thedudeabides157
    thedudeabides157 New Member
    I keep seeing a module that is said to be necessary for vehicles with reverse cameras. Looking into the 48'' opt7 triple led but no one talking about it on any thread here. Just the curt wiring adapter is only necessary?
  2. May 22, 2021 at 6:39 AM
    number1stunna
    number1stunna Active Member
    2016 TRD Sport
    Get the curt adapter and a bullet connector to wire the reverse light and you'll be all set. It's actually a real simple install, and I followed this guy's instructions. I did use 3m locking velcro so I can remove it to access the spare if needed. I didn't remove the tailgate, and using the bullet connector means you don't need to solder the wire.
    https://www.youtube.com/watch?v=t7nnIu1GpJo
  3. May 22, 2021 at 9:19 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    I have the bar on my truck. used the curt harness, and some plastic "velcro" with 3M trim tape to install. The bar was easy to pull off when I had a flat to access the spare and after repairs to return the spare.
    One of my fav mods.
  4. Oct 18, 2021 at 11:02 PM
    whippiol
    whippiol New Member
    Pol
    2021 Tacoma SR
    I don't have the trailer package (2WD SR) I just hardwire the wires to my left tail light, but how to make the signal light on the LED light bar works? I connected the green and left to the brake light.
  5. Oct 18, 2021 at 11:52 PM
    emmarx2
    emmarx2 New Member
    mwahne
    PDX
    -21 Tacoma Trd Pro
    Mictuning (27” triple led lights) in aluminum casing is another option. Two piece and you’re clear for the spare tire at all times. Installed on 21 Trd Pro using trailer conn for temporary but also can be hard wired as well.
    opt7 ????? Failure awaiting???
  6. Oct 19, 2021 at 4:45 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Opt lightbar is garbage I had one it started to drain my battery while the truck was off . Took it off and the problem went away .
    Taco_Coma likes this.
  7. Oct 19, 2021 at 12:15 PM
    TC_Mic
    Sorry for your luck @GOTSAND?18
    My bar has been on the truck since March '17 excluding the one day (3 or 4 hours actually) I removed it due to a flat. Have not had a single problem with it. I used the 4 pin hidden hitch adapter and tapped the driver's side tail using a bullet connector to the bar for the reverse lead. For access to the spare I used a plastic velcro like strip in each side of the access hole. I can pull the bar off and have left just enough slack in the lead line to lay it on the bumper while changing the tire.
    This is my 4th Opt7 bar through 3 trucks. The 1st bar (had plastic back vs the aluminium that is now used) was damaged by a tire shop when they were trying to access the spare tire.
    Mictuning may be a good option, I have switches from them that have worked fine. Did not see their offering when I got this truck, though I likely would have stuck with Opt7 since I have had good results with them previously. The split design might have made the install and any work with the spare a bit simpler.
  8. Oct 19, 2021 at 4:47 PM
    Veggie Taco
    Veggie Taco Well-Known Member
    Sean
    South Lake Tahoe
    2020 Tacoma TRD Off-Road [MGM]
    Everything, except the ones I haven't done yet ;)
  9. Oct 19, 2021 at 7:59 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have the opt-7 and it works great
    Capespencer68 likes this.
  10. Oct 19, 2021 at 8:02 PM
    shotgunbilly420
    Never had this issue in going strong two years
  11. Oct 19, 2021 at 8:41 PM
    Agent 54
    Agent 54 Active Member
    2021 Taco TRD Sport
    None....yet..
    Any video/photo of what this looks like on the backup camera? Should it be installed with the backup light on the top or bottom?
  12. Oct 20, 2021 at 12:57 AM
    TC_Mic
    You need to install with right and left orientated correctly or your blinkers will be flashing the opposite direction as the tails. The wire lead will be on the driver's side when installed correctly. As I recall that puts the reverse across the top of the bar.
  13. Dec 31, 2021 at 3:57 PM
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
  14. Jan 2, 2022 at 4:02 PM
    Capespencer68
    Capespencer68 Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    OPT 7 all the way! Love mine.
    shotgunbilly420 and TC_Mic like this.
  15. Jan 17, 2022 at 12:01 PM
    #35
    Capespencer68
    Scott
    Massachusetts
    On the OPT7 I used 3M heavy duty outdoor Velcro so I can easily remove the bar for a spare tire drop down.
    TC_Mic and shotgunbilly420 like this.
  16. Jan 17, 2022 at 12:05 PM
    #36
    shotgunbilly420
    Same here with the Velcro
    Capespencer68[QUOTED] likes this.
  17. Jan 17, 2022 at 12:31 PM
    #37
    Veggie Taco
    Sean
    South Lake Tahoe
    3M Dual Lock FTW.
    TC_Mic and Capespencer68 like this.
  18. Jan 17, 2022 at 12:33 PM
    #38
    Capespencer68
    Scott
    Massachusetts
    yep, that’s it. Works great
  19. Jan 18, 2022 at 11:20 AM
    #39
    Sroberts
    Sroberts Well-Known Member
    Sean
    Vancouver, Canada
    2017 Tacoma TRD O/R Blazing Blue DCSB
    Well ain't that smuckin' fart.. then if it craps out its an easy swapout
    I keep seeing tailgate strips with sections burnt out. I guess unless you test it regularly its bound to happen.
  20. Jan 18, 2022 at 1:57 PM
    #40
    Capespencer68
    Scott
    Massachusetts
    That’s why I went with Redline’s OPT7. High quality and sealed in a aluminum holder. Plus I believe it’s either a two or three year warranty and they can fix any lights that might go out. It’s those cheap strip lights that always craps out.
    TC_Mic and Sroberts[QUOTED] like this.
