Tailgate load Weight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rusty98, Feb 10, 2017.
  1. Feb 10, 2017 at 10:32 PM
    Rusty98
    Rusty98 [OP] Member
    New Jersey
    2017 Tacoma Limited
    Interior LEDs Window Visors Bed Extender OEM Bed Mat OEM Bed Cover ***I am sure there will be more to come****
    I just purchased a 2017 Taco Limited and I cannot find the max load of the tailgate. I searched TacomaWorld with no luck. Can 3 adults sit on it?
  2. Feb 10, 2017 at 10:43 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Depends how "portly" these adults are.
    BSFord, LoMa, jtmiller2011 and 9 others like this.
  3. Feb 10, 2017 at 10:54 PM
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    Like the post office says,
    If it fits, it sits
    Joe23, Kilokato and 0210 like this.
  4. Feb 10, 2017 at 11:01 PM
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    I could not find the load rating anywhere. But yeah, I load dirt bikes with no issues and have sat 2 adults and a kid on my tailgate. No issues at all.
  5. Feb 10, 2017 at 11:59 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    I'm 180lbs and have stood on my tailgate many times. No issues.
  6. Feb 11, 2017 at 1:33 AM
    Gravybird
    Gravybird Active Member
    Central MN
    17 Black TRD Sport DCSB
    Predator tube steps, mud guards, Tonneau cover, TRD exhaust
    I was also wondering this same thing for hauling my motorcycle. Only way it would fit would be tailgate down.
  7. Feb 11, 2017 at 3:58 AM
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    I've had 400 pounds on mine without breaking it. My previous vehicle had a 300lb static weight limit for the tailgate and only had 1 supporting cable.
  8. Feb 11, 2017 at 7:08 AM
    SRQ_TACO16
    SRQ_TACO16 Well-Known Member
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    My dealer looked at me like I was an idiot when I asked them what the max load is. They explained there isn't a max and if I broke it its my fault. I've also had 3-500 pounds on mine. Every once and a while it should be fine, but I need to do it almost every day. I will no longer use the Tacoma tailgate until I can find someway to reinforce it. Using a tundra in the mean time, but it is honestly not much better. This was surprising as we've never had this problem on any of our other trucks.
  9. Feb 11, 2017 at 7:16 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Kbvoodoo sells bed reinforcements i beleive
  10. Feb 11, 2017 at 7:25 AM
    SRQ_TACO16
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    Bed seems fine just the tailgate flexes and bends going to try to get a metal plate made for it to replace the plastic and see if that helps.
  11. Feb 11, 2017 at 7:52 AM
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
  12. Feb 11, 2017 at 8:16 AM
    ManBeast
    Zach
    Orange Park FL
    I knew it was 1 of them 2
  13. Feb 11, 2017 at 8:29 AM
    drwx
    M'boro, TN
    Even with reinforcement of the tailgate itself, that will just prevent it from bending....A rigid tailgate isn't useful if the mounts snap off.
    0210 likes this.
  14. Feb 11, 2017 at 8:34 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    On the past it was the tailgate that bent first.
    I think the official max weight is zero. Toyota does not rate the tailgate to hold more than its own weight. I don't think any tailgate has a rating. That's why they all easily come off for loading heavy items.
  15. Feb 11, 2017 at 8:57 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I've put a 28 cu ft fridge on mind loading it up from lowes and unloading.
  16. Feb 11, 2017 at 9:00 AM
    Psycho2
    Psycho2 Well-Known Member
    AZ
    '16 DC TRD Sport Barcelona
    I wouldn't be too worried about the mounts snapping off. The support cables attach with some pretty serious bolts to the strongest parts of the tailgate and bed. If you are loading things that heavy, it would be best to look into aftermarket options. The above mentioned tailgate reinforcements should allow any reasonable item to be loaded into the bed.
    CusterFan likes this.
  17. Feb 11, 2017 at 9:55 AM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I had stupid amounts of weight across mine, dead center of the gate and never had a problem. Six 12' sticks of 3" square x 3/16" wall tubing bouncing down the highway. That's about 600 lbs.
  18. Feb 12, 2017 at 6:44 AM
    SRQ_TACO16
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    Awesome, I'll check them out!
    A little backstory, we sell machinery and most is delivered via a ramp attached to our tailgates. In the past we have owned GM products, a Titan, and a Ridgeline and this is the first time we've had tailgates actually bend or flex. My request is not at all unreasonable as the Chevy and GMC were used for 10 years each doing this same thing on a stock tailgate and never a problem. Titan and Ridgeline not as long, but still no issues. I am more surprised though that the Tundra tailgate is so weak. Sort of expected the Tacoma to be.
  19. Feb 12, 2017 at 9:12 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I believe the first gen Tundra had problems but they were corrected with the second gen Tundra.
  20. Feb 12, 2017 at 9:24 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    The 3rd generation Tacoma tailgates are supposed to be stronger then the 2nd gen.
    Mobtown Offroad likes this.
