Tailgate Lock Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TTM556, Jul 3, 2018.
  1. Jul 3, 2018 at 7:30 PM
    TTM556
    TTM556 [OP] Well-Known Member
    2016 Stock Taco Double Cab
    Stock
    Hello. I cannot get the key to insert into the lock on my tailgate. The key inserts about a 1/4" and stops. I tried spraying a little silicone lube in it with no avail. I placed a small screwdriver in the lock and it seems to move around unrestricted. The key works fine in the cab doors. Thoughts?
    We purchased the truck used with 20k on the odo so who knows what the previous owner did but I would have a hard time imagining he changed the locks. What am I missing here?
  2. Jul 3, 2018 at 7:34 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The 2016 uses a different key in the tailgate than the ignition/door lock key. My guess is you have a 2016 and who you bought it from didn’t give you the tailgate key.
    over60 likes this.
  3. Jul 3, 2018 at 7:38 PM
    TTM556
    Stock
    Ah. Copy. Why in the heck did toyota make the tailgate lock different from the cab?
  4. Jul 3, 2018 at 7:41 PM
    mutely
    It was a dumb decision that they rectified in the 2017 model. Put a power lock on it so it works with central locking system and forget it.
  5. Jul 3, 2018 at 7:42 PM
    TTM556
    Stock
    I'm going to have too. Is there a preferred brand? Popnlock?
  6. Jul 3, 2018 at 7:44 PM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Probably a supplier issue. The tailgate handle assemblies are the same on the tundra as well. I'm sure it was challenging logistically to match them to the keys for the Tacoma.
  7. Jul 3, 2018 at 7:49 PM
    mutely
    That seems to be the one people prefer and it’s the one that some distributors use, (mine came with one installed from the dealer). If I was going to do it myself, I’d follow the DIY thread where you can do it for $20. Popnlock is no better than any other quality wise, still cheap shit, but it does supply a complete kit vs sourcing cable / actuator / connectors & mount separately.
    TTM556[QUOTED][OP] likes this.
  8. Jul 3, 2018 at 7:52 PM
    TTM556
    Stock
    Copy. I will check the DIY section. Thanks
  9. Jul 4, 2018 at 10:50 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Check the inside of the lid of the center console. There is a clip designed to hold a pen that people have found is perfect for holding the tailgate key. Yours might be there.
  10. Jul 4, 2018 at 1:34 PM
    Nutz45_1
    Nutz45_1 Well-Known Member
    James
    Mullens West Virginia
    2016 Tacoma sr black on black
    Hids low beams,all inter LEDs, ultra motor sport wheels 265/65/18 bfg a/t KO2s 6k rev lights led tail an brake new taillight covers
    Mine is a 16 and it's doesn't have a key spec. For the tailgate one key fits the door an the tailgate
    kite_325 likes this.
  11. Jul 4, 2018 at 4:38 PM
    RichVT
    Rich
    Northern Vermont
    The trucks with keyless ignition have a small key in the fob for the doors and a separate regular sized key for the tailgate. Spend more money and you get a dumber system.
  12. Jul 4, 2018 at 5:12 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    does that also work for the glove box?
  13. Jul 4, 2018 at 5:37 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    WRONG!
    Tiny key in the fab fits everywhere.
    dpippel likes this.
  14. Jul 4, 2018 at 5:38 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    ^^ Correct.
  15. Jul 4, 2018 at 5:49 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Not in 2016
  16. Jul 4, 2018 at 7:23 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Was not referring to B.C era.
  17. Jul 4, 2018 at 7:35 PM
    daddy_o
    Bossier City, La
    Since OP has a 2016, it was relevant info.
  18. Jul 4, 2018 at 7:41 PM
    Nutz45_1
    James
    I see I got the cheap one made it my way
  19. Jul 4, 2018 at 7:46 PM
    Dacon
    Danny
    Gilbert, Arizona.
