Tailgate Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fredfarmer, Aug 28, 2022.
  1. Aug 28, 2022 at 7:45 AM
    fredfarmer
    fredfarmer [OP] Well-Known Member
    DFW
    2016 TRD Off Road AC
    I have a 2016 Taco but did not receive the tailgate key. Since Toyota screwed up royally on this, I cannot get them to sell me a replacement. I have tried giving them the VIN and nothing comes up in their system. I have also given them the number off of the cylinder and they say they (2 dealerships) cannot get the key from that.
    I think I can drop it off at a locksmith and they can take the tailgate cover off and make one that way. Does anyone else know how I might be able to get the correct key?
    If not, I will go aftermarket and look for an automatic lock so I am also looking for recommendations on those.
    TIA for any info/assistance on this!
    FYI - The 2016 is the only year that the tailgate key was different than the door key. I have also looked under the console lid were the clip is that is designed to hold it.
  2. Aug 28, 2022 at 7:54 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Why not buy a tailgate handle/lock cylinder assembly for a 2017+ and have a locksmith change it to match your master key?
    I don't have the p/n handy, but the add-on power lock kit from Toyota for the tailgate is plug-n-play. Takes about an hour to install.
    Hairless_Ape and fredfarmer[OP] like this.
  3. Aug 28, 2022 at 8:07 AM
    fredfarmer
    DFW
    The dealer that I spoke to about that said the OEM power lock was discontinued. I like the 2017 idea, I'll keep that in mind. Thanks for the suggestion.
  4. Aug 28, 2022 at 8:24 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    The OEM tailgate key is of a weird design; it is not a standard type key with teeth. I can't find anyone who can cut me a new key.
  5. Aug 28, 2022 at 9:04 AM
    blu92in99
    Justin
    Elk Grove, Ca
    Here's the part number for the tailgate lock cylinder for your '16, comes with two keys. Looks to be about $65
    69055-0C030
    fredfarmer[OP], Greg-tacoma and TRD75 like this.
  6. Aug 28, 2022 at 9:08 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    The R4T one works swell, also plug and play. Very easy install, takes about 30 min - definitely my most useful mod to date
    https://runnin4tacos.com/products/tailgate-lock-3rd-gen-tacoma-2016-2021
  7. Aug 28, 2022 at 9:48 AM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Tried my tailgate lock yesterday for the first time after reading about tailgate keys. Stuck my ignition key and it worked fine.
    Is yours push to start?
  8. Sep 6, 2022 at 2:21 PM
    fredfarmer
    DFW
    Yes, it is PTS, the 2016 is the only year on the 3rd gens that had a separate key for the tailgate. I bought mine used and it did not come with a key, so yea... Lucky me!
  9. Sep 6, 2022 at 2:31 PM
    fredfarmer
    DFW
    The dealership quoted $480 to replace it, so aftermarket here I come. I know about the pop and lock and the one posted above, anyone have any other suggestions?
  10. Sep 6, 2022 at 3:22 PM
    zorg
    zorg New Member
    2016 Inferno TRD Sport
    Swear the stealership stole my key, juts called them to quote and it’s $99 for the core and the key and $125 to install.
    I also have the 2016 with PTS, then the tailgate has a full size key & the glove box opens with the hidden fob key.
  11. Sep 6, 2022 at 3:27 PM
    Stuck in VT
    Utah
    2019 SR SX MGM
    Man that sucks! A lot of differences even within the 3rd gen and we're on to the next one.
  12. Sep 6, 2022 at 5:32 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I was dealing with this when I lost the tiny key from the fob of my push to start. They are called “laser cut” keys. I wound up sending pics to an eBay seller who cut and sent a replacement fob key.
    So that’s an option if you still have a key that works and you can take pictures of it
    willtill[QUOTED] likes this.
  13. Sep 6, 2022 at 6:16 PM
    shark56
    shark56 Well-Known Member
    Is your tail gate currently locked?
    If not, I would order the lock/key set from the above post.
    If it is locked, you might have to remove it from the inside which might cause a little damage to the tail gate cover but still be cheaper than that crazy dealer quote.
  14. Sep 6, 2022 at 9:29 PM
    Northwest Missouri State
    Northwest Missouri State Archetypal
    98 Tacoma TRD OR 5MT, 20 TRD OR 6MT, 12 FJ Cruiser AT
    All 3 supercharged w/ other performance mods.
    Really? Did he say when? I had the remote lock installed on mine at my dealer approx one month ago.
  15. Sep 6, 2022 at 9:53 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Get a pop n lock and call it good. I've had mine in for several years and love it.
  16. Sep 7, 2022 at 6:26 AM
    willtill
    Maryland
    Thanks!
    I do still have the key. Did you use this Ebay laser key cutting service provider?
    https://www.ebay.com/itm/153100290117
    musicisevil[QUOTED] likes this.
  17. Sep 7, 2022 at 7:14 AM
    fredfarmer
    DFW
    Another dealership quoted $480 for an OEM auto lock installed. My concern with the aftermarket auto locks is that I do not have a key. I have a metal tonneau cover and I'd be screwed if the auto lock failed and I do not have a key for back up.
  18. Sep 7, 2022 at 8:03 AM
    musicisevil
    Alaska
    2019 TRD Sport
    That’s the one! I had the little key plate with the code that comes with the keys from the factory, but for whatever reason the seller said that wasn’t sufficient and so I sent pics as well. Ordered two and they both work and fit in the fob
  19. Sep 7, 2022 at 11:30 AM
    shark56
    If you are going to install an after market lock yourself just get the OEM one from Toyota.
    It took me longer to get my tools out than to actually install the lock. OEM kit is plug and play. About $150 or so. The price the dealer gave you is probably tacking on two hours labor for a job that would take less than 30 minutes.
  20. Sep 7, 2022 at 1:01 PM
    TRDMobile4x4
    TRDMobile4x4 Well-Known Member
    Nathan
    2019 Cement Grey Tacoma TRD Off-Road
    While you got the lock out you should upgrade to an electric lock, don’t even need to use the key after that. (But still should get it fixed in any case, electric lock or not)
